| Home | Forums | Gallery | Register | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
| Everyday Impreza Talk If it doesn't quite fit in any other forum, but it's related to the club in someway, discuss it here. General suggestions, questions, and comments welcome. |
| Advertise On ClubWRX | ||
LinkBack | Thread Tools | Rate Thread | Display Modes |
#1 (permalink) |
Parking gear-1st or R?
I've heard a couple of different theories on this so I want to get your input..which gear (in an MT, ofcourse) should you leave your car in when you park? This is what I do:
Level: 1st +E-brake Downhill: R+E-brake (Wheels to right) Uphill: 1st+E-brake (Wheel to left) I've heard that there are different recommended gears for different trannys when parking..some say 1st, others R, still others say spread it out to even the wear and even include 2nd and 3rd in the rotation. I've also heard about E-brakes locking up when left engaged over extended periods(like when on vacation)..this seems to be more severe in the winter months. So in these cases, should you just leave it in gear without engaging E-brake. Does e-brake provide any additional support if gear is already engaged. Last thing..my situation is complicated in the winter because I'm spoiled by a remote starter that requires car be in neutral. But I only need the remote starting at work or overnight at home, both of which are level, so I don't think E-brake is too stressed acting solo. Thanks |
#3 (permalink) |
ClubWRX Grammar Czar
I only leave it in N and E-Brake it unless on a severe incline.. but the examples you gave are the most correct.
I've been doing this for 40k miles, and the E-Brake has never slipped... so you're fine with your remote start and just the E-Brake in my opinion.
__________________
- Kevin ....... '06 SGM WRX - VF39'd @ 293whp 346wtq 13.6 @ 98mph 1.8 60ft @ 6000ft Elevation Your friendly Colorado Moderator - Colorado Member's Forum Sponsored By:WRXPro.com AIM: SinisterSooby |
#4 (permalink) |
Sammich Makin Pwincess #1 |
this is what i do:
flat surface: ebrake + 1st downhill: ebrake + 4th uphill: ebrake + 1st
__________________
your friendly, neighborhood subaru girl 06 wrx impreza: cobb stage II! // 1991 toyota aristo; totally stock & JDM, y0! myspace; facebook hawk-eye alliance #1111 // wingl3ss @ll!ance #17 |
#5 (permalink) |
4th doesn't make any sense to me... when you drop start a car, usually it's in 3rd or 4th... it seems like it'd be easier for the car to roll down hill in 4th. Can you explain your reasoning behind this hun?
__________________
#6 (permalink) |
i dont have a reasoning for it
![]() i just dont feel comfortable leaving it in reverse, even if it does make more sense to leave it there. perhaps it has something to do with my OCD lol
__________________
#7 (permalink) |
Flirty User That's Younger Than the Chunks of Corn in Brian's Crap |
When I park, I park
on a level surface, 1st, uphill, 1st and e-brake or just 1st, depending on the hill, downhill, R and e-brake, again, depending on the hill, sometimes just R. Lately though, my car skips gears so I just avoid hills. |
#8 (permalink) |
You just made me question every post you've ever made
jk jk
__________________
#9 (permalink) |
i tend to only use the E-brake, i realy havent needed or more or less cared about putting it in first. i think if the E-brake is gonna slip while on a hill, first or reverse really isnt gonna help if the E-brake cant hold it. but thats just me and my $0.02.
#10 (permalink) |
If the hill is steep enough (like 50* and up or something), then yeah I think the car will probably roll. But in most cases, 1st gear and reverse can help the parking brake. Same applies if youve ever tried pushing your car while its in first and no ebrake.
__________________
--Justin Hawk-Eye Alliance #128 |
#11 (permalink) |
I leave it in neutral with no E brake.
When its on a hill, I let my car rest on the car behind me or the fence/wall behind. ![]() nah seriously, i leave it in neutral with e brake on a flat surface, but 1st gear and e brake on a steep enough hill.....or in a bad neighborhood lol
__________________
Bugeye Mafia #213 Kevin 2002 Midnight Black Pearl WRX 05 STi 6 speed transmission with Brembo brakes ![]() EVOIII 16G+ supporting mods 304whp/290wtq on a DynoJet |
#12 (permalink) |
I guess I'm bad... I leave it in N with the E brake on level ground.
One time, I did forget to pull the e brake on the GTO and it rolled out of it's parking space in a mall parking lot. No damage (just went 10 ft and didn't hit anything), but I was real idiot.
__________________
06 GTO M6 Quicksilver 455 Bobcat (not dyno'd) 07 WRX TR M5 w/PPGs Garnet Red Pearl (dyno'd 315whp/334wtq) -- "Just remember. Even if you lose, your still a winner... At losing..." |
#13 (permalink) |
E brake and 1st on flat ground.
E brake and 1st facing up hill with wheel cut. E brake and R facing down hill with wheel cut.
__________________
2004 PSM WRX 1979 Camaro Z28 1993 Silverado 6.5 TD 1974 Honda CB750 cafe racer project blObeye SYNDICATE #88 "In art, as in love, instinct is enough." |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| which one is a better gear ratios? 07 WRX MT | StageWrx | Transmission & AWD | 4 | 04-01-2007 06:33 PM |
| 1st Gear Grinding | Peteys02bugeye | Transmission & AWD | 14 | 02-14-2007 11:17 PM |
| (One more) 1st Gear Problem | Red Ride | Transmission & AWD | 12 | 07-22-2006 04:15 AM |
| 1st gear, right-hook shaped? | theorie | STi Transmission/Drivetrain | 8 | 07-07-2006 08:09 AM |
| grinding problem with 1st gear and reverse! | BlueScooby | Transmission & AWD | 0 | 11-16-2002 07:05 PM |
