Gas Mileage FAQ - Page 19
Page 19 of 19 FirstFirst ... 910111213141516171819
Results 271 to 281 of 281
This is a discussion on Gas Mileage FAQ within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; Thanks for the replies. I was a bit surprised because at fuelly.com my mileage is one of the worse and ...
  1. #271
    Feb 2014
    Thanks for the replies. I was a bit surprised because at fuelly.com my mileage is one of the worse and I was thinking "how the hell does these people do that mpg"? That's why I thought something was wrong.
    Anyway, I enjoy my ride everywhere I go, so screw my mpg.
  3. #272
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Pepezeta. Published city mileage for your year is 17-19mpg. Glad you're having fun with it though!
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  4. #273
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Tricky question. Short side of it, if you drive conservatively now... You'll improve mileage. If you drive aggressively now... It'll get worse. Below are my explanations.
    Cold air intake brings in colder air, colder air means leaner condition which the ECU compensates for by injecting more fuel. (that's why we have an IAT bulb in the MAF housing).
    The cold air intake is less restrictive. That means less resistance, which means more power at lower RPMs with less throttle.
    So... With conservative habits, the mileage should be better. With aggressive habits, it should be worse.
    Less restrictive exhaust means more flow, more scavenging and therefore more volumetric efficiency. More efficiency means more gas mileage. But, it also means at higher throttle percentages, more air and fuel can be injected.
    Sorry Kevin, this is where I disagree. While improved flow does indeed increase VE, warm air increases fuel atomization which (in term) leads to a more complete burn. A CAI reduces air temps (at the injection point), reduces the fuel atomization, and should net worse economy.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  6. #274
    Nov 2006
    Denver Metro Area
    Gas Mileage FAQ
    I'll bite. You're wrong.
    Your cold air goes through a hot turbo. Our coolest intake temps (after warm-up) are still higher than the highest intake temps that street driven NA cars make.
    The best drag times are in the late evening after a drag strip was heated up all day, but the air has cooled down from the sun going down. Or on a warm day that a cold front just moved in.
    The difference in fuel atomization from heat isn't enough to matter for anything. Within normal operating temps. If it were... Then the inter cooler efficiency wouldn't matter to us, or inter cooler sprayers. Nor would water and methanol injection, or "wet" nitrous injection.
    As far as fuel atomization... Age and condition of your injectors will matter a lot more than intake temps.
    Love you sweet-t!ts,
    Kevin
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  7. #275
    zax
    zax is offline
    Nov 2008
    I will admit that winter-driving tends to have worse fuel economy for a variety of reasons:
    1. Increased ethanol content in fuel
    2. Lower pressure in tires OR softer winter tires
    3. More time spent in Cold Start enrichment
    However I do believe that lower intake temps will lead to reduced fuel atomization. You are correct about the TMIC, but since the compressor follows adiabatic expansion and radiative cooling, delta T in = delta T out (rough simplification).
    Facebook me here
  8. #276
    Nov 2006
    Denver Metro Area
    All I heard were a bunch of smart person words and "you are correct".
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  9. #277
    zax
    zax is offline
    Nov 2008
    Womp womp
    Facebook me here
  10. #278
    Registered User Jeff_34's Avatar
    Aug 2014
    I saw better gas mileage after I installed my AOS. I have a 2011 STi sedan stage 2+ Cobb OTS with 11.3 lb flywheel. Went from 22ish to 24ish city. Probably from the lack of degradation of the octane by cutting the oil vapor out of the intake air supply; sounds legit.
    Sent from my iPad using Tapatalk
  11. #279
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    GREAT write-up Sinister. I do all that stuff you spoke of, to get better mpg. A side affect of keeping my 2000 Regal tire pressures on the high side was that I got 135,500 miles on the OEM Firestones before ever buying a new set of tires for the car! I posted recently about getting 31.2 mpg on my new 15 WRX. Today on arriving at work the screen is showing 31.8 mpg. If I slow down to the speed limit everywhere I am sure I could get close to 33 mpg. I might try that next tank, just to see how high I can get it. I love your write-up; its dead on.
  12. #280
    Nov 2012
    Ohio
    Caring about your mpg is great, but if you really care that much then you bought the wrong car. Gas plus air are required to make power. If you want a fast car, gasoline consumption goes with the deal. Personally, I never check my mpg. I bought this car because it is practical and fun to drive. The fun part is a heavy right foot.
  13. #281
    Feb 2015
    Ohio
    Dangit! I bought the wrong car!
