Project Hatch (aka project grocery getter part II) - Page 9
Page 9 of 66 FirstFirst 1234567891011121314151617181959 ... LastLast
Results 121 to 135 of 984
This is a discussion on Project Hatch (aka project grocery getter part II) within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; thought you guys might be interested in a stock 09 dyno run (dynojet, 3rd gear pull)- I saw slightly underrated ...
  1. #121
    Jul 2001
    Plains of Eastern Montana
    thought you guys might be interested in a stock 09 dyno run (dynojet, 3rd gear pull)- I saw slightly underrated from the factory- look at the torque #'s
    pic courtesy of subytek
  3. #122
    Apr 2004
    Southeastern PA
    Wow ... stage 2 will make it a monster.
    Mods & Pics
  4. #123
    Registered User 05Wrex's Avatar
    In the middle of a corn field somewhere in Illinois
    Nice numbers especially for stock. Did you do a reflash while out there or are you gonna leave the map stock.
    OBP 2005 Wrx - Big 16g
  6. #124
    Jul 2001
    Quote Originally Posted by 05Wrex View Post
    that's not my run, rather subtek's,- mine only has 350 miles on it
    I plan on getting a base dyno run w/ mine after 1000 miles- I'm going to run D Stock next year- so no flash. I am going to get a few runs stock and then bolt on my catback/panel filter and see if there is any bump
  7. #125
    May 2005
    Phillytown, PA
    Those are some seriously crazy numbers. What is the 08-09 STi doing stock?
    Also, this car is going to be a monster in DS.
  8. #126
    Jul 2001
    my understanding is slightly higher, considering the vf52 is essentially the vf48 squeezed into a LGT style housing and they share the same block- makes sense that the #'s are going to be somewhat close
    clearly they underrated the #'s on the 09 WRX, probably much less underrated on the STi
  9. #127
    May 2005
    Phillytown, PA
    That's what I was wondering. I'll have to look to see what the stock boost is for these two. Depending on the gearing, (5MT usually better for AX) I'm curious if this thing could give the STi a run in STU.
  10. #128
    Yeah don't know what I was thinking.
  11. #129
    Jul 2001
    Quote Originally Posted by wrx wagone View Post
    stock boost for the 09's WRx is reportedly 13.3 psi, STi reportedly 14.7
    the 08 WRX was 11.3 IIRC
  12. #130
    Oct 2008
    Why such a big variance among the 3 dyno runs? Heat soak?
    Impressive torque numbers, though. It would be nice if the torque curve were flatter instead of dropping off after 4000 rpm, but still pretty awesome with over 200 ft-lbs from 3000 to 5500rpm.
  13. #131
    May 2005
    Phillytown, PA
    The lower boost on the 09 WRX, would hurt it against the STi. It is only a pound or so... this may be interesting,
  14. #132
    Oct 2008
    Ohio
    I am a little confused, max power from that 09 is 230 hp, but I thought that 09 had 265 hp. I thought that the 265 hp was at the wheels, but it sounds like that must be at the crank.
    Just seems weird because the stock values are 265 hp and 244 ft.lbs of torque; and yet the numbers that you provided the torque is higher than the power. Am I missing something?
  15. #133
    May 2005
    Phillytown, PA
    Quote Originally Posted by gearhead364 View Post
    Welcome to the world of fabricated, or at least underrated, power numbers from the manufacturer. Subaru states numbers at the crank, where the dyno numbers are at the wheels.
  16. #134
    Oct 2008
    Ohio
    In that case, WOW, those numbers are good 272 ft.lbs at the wheel, just a little underrated.
    Question, does anybody know how torque and power losses scale with relation to each other? Is it simply a linear relationship since Tq = P * revs?
  17. #135
    Jul 2001
    Quote Originally Posted by jabrabu View Post
    yes heat soak, he stated it was pretty bad
    those numbers are at the wheels (whp)- figure roughly a 20% drivetrain loss for an awd Impreza vs crank (chp)
    not sure on the torque equation- I'll let someone else to a stab at that
