Project Hatch (aka project grocery getter part II) - Page 48
Page 48 of 66 FirstFirst ... 383940414243444546474849505152535455565758 ... LastLast
Results 706 to 720 of 984
This is a discussion on Project Hatch (aka project grocery getter part II) within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; All this talk of spring rates and struts makes me giddy... Cant wait till I get my dspecs/ RCE blacks ...
  1. #706
    Registered User wrxmuch?'s Avatar
    May 2008
    Nashville
    Cant wait till I get my dspecs/ RCE blacks in my 2004 wrx this winter for the next autox season!
    Cobb Accessport v1 stage 2 93 map, Nitto Invo Tires, Sti Front and Perrin Rear Sways, Rota Torque Wheels, APS Exhaust 3.5" turbo back. Catless TurboXS Up pipe, Goodridge Stainless Steel Brake lines, Hawk HPS Brake Pads, Paranoid Fabrications Cowl Braces, Group-N Tophats, Group-N Trans and Engine Mount, Tokico Dspec w/ Rce Black springs
  3. #707
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    So Mike you have owned the car for about a year or more....are you as attached to this one as the old one?
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  4. #708
    Jul 2001
    Plains of Eastern Montana
    I am I really like what Subaru has done w/ the 09 (and 10)- stepping up the performance (engine and handling) is the right direction to go. I like the looks of the new body style as well (interior saw a lot of nice touches too)- the older wagon style is still very attractive IMO, but so is this.
    I miss the mpg of the 2.0 liter, but the new car isn't too bad 25-27 on the interstate (80 mph). While it would be nice to see 27-29 like I used to, I'm more than happy to give that up for all the additional torque
    Mike
  6. #709
    Jun 2006
    Nor Cal
    Mike
    God I was Cali had MT gas. My 06 wrx gets 23mpg highway. My buddy just bought a silver 10 hatch and hes averaging 23 highway as well.
    I wonder if elevation comes into play. We are at sea level and more air =more fuel. hummm
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  7. #710
    Jul 2001
    we have crappy gas too- 91
    I would think increased elevation would decrease mileage ?????
  8. #711
    Jun 2006
    Nor Cal
    Yeah but Cali gets the ACN blend which decreases mileage substantially. I drive to Oregon and get 2-3 mpg better right out of the gate.
    I would think the opposite about the mileage with elevation. At higher altitudes air is less dense. Since the computer regulates fuel flow and is constantly monitoring the situation through the o2's, I would think that less air = less fuel. The ECU is going to try to hit the MAF value targets programmed in. So I would think that mileage would increase because less fuel is being pumped in, and power would decrease.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  9. #712
    Jul 2001
    I guess we do get better gas
    a search of the intraweb yields no consensus on gas mileage and elevation (that I could find)- there is a consensus that you lose power (hence the reason some time they use a correction factor for 1/4 mile times- always quicker at sea level)
  10. #713
    Dec 2009
    NC
    Big Sky,
    What is the diameter of the rear koni body? I want to make sure it will fit in the lathe I have access to.
    Also, what are the dimensions of the circlip grooves? Is it just a square cut? How deep/wide is the groove. I have a 125 thousandths square parting tool that I was wondering if it'd work.
    I'm thinking about turning my own urethane bushings for the konis. Would 82A durometer be too hard. What where those whitelines? Do you still have the pins that go through the WL ones you bought? If so what are the dimensions (ID is 12.22mm)?
  11. #714
    Jul 2001
    Quote Originally Posted by 09rexwagon View Post
    Big Sky,
    I'm out of town for a couple of days, I'll see what I can report when I get back.
    Mike
  12. #715
    Dec 2009
    NC
    Mike
    I appreciate it. No rush.
    I have a bar of 82A durometer urethane that is 2.25" in diameter. I hope to use this to turn down my bushings for the koni rears. Are the eye holes less that 2.25". I assume so from your pictures, but just making sure.....I want to avoid a McMaster order if all possible. You know how it goes, if you have to place a Grainger/McMaster order it always works out to be a few hundred bucks because you ALWAYS order more crap than you need .
    EDIT: damn, I need some steel rod for the pins anyway, McMaster it is .
  13. #716
    Dec 2009
    NC
    By the way, I've contemplated upgrade brake pads or getting some autox only pads, but in the events I've been in (doing street tire DS) there has never been a time where I've encountered a fade situation, nor a time where I was limited in braking ability due to the brakes themselves. The tires are always the limiting factor and hence ABS being activated. Are the Dunlop SP Sport 01s really that mediocre?
  14. #717
    Apr 2008
    West Allis, WI
    Compared to r-comps, yes, they are mediocre. Compared to the top street tires they are probably a 6 or 7 out of 10.
  15. #718
    Dec 2009
    NC
    Quote Originally Posted by BSTON View Post
    Oh for sure compared to r comps.
    I'm going to do street tire DS for the year, so I was wondering if anyone else was finding a situation where the street tires were so grippy (as in ABS didn't enter the equation) such that the OEM pads proved inadequate. While autox is tough on brakes, fade generally isn't something we'd encounter.
    I will probably get some Hawk HP+ for track only down the road, but I'm just trying to figure out what benefit I'd be getting if I'm limited by tire traction and not braking ability/efficiency/fade etc.
  16. #719
    May 2005
    Phillytown, PA
    If I didn't have as much done to my car as I do, I'd likely make the move to a new WRX.
    I really like what you've done with yours Mike.
  17. #720
    Registered User tuskenraider's Avatar
    Aug 2004
    Chicago area
    I find the stock pads just fine for autox. No street tire will overtax them in most driving situations. I'll change to something else when they wear out, or find I don't like them with r-comps if I go that way next year.
    '11 WRX Hatch
    Lightning Red
