ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Community - Meet other Enthusiasts > Everyday Impreza Talk
Everyday Impreza Talk If it doesn't quite fit in any other forum, but it's related to the club in someway, discuss it here. General suggestions, questions, and comments welcome.
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 02-11-2009, 04:43 PM   #316 (permalink)
Moderator
Big Sky WRX's Avatar
they make a "matching" 08/09 one- this is the one I got
45mm Electrical Boost Gauge - 08+ WRX/STi
what I don't know is how well it matches when everything is lit up
__________________
Big Sky WRX is offline   Reply With Quote
Old 02-11-2009, 08:10 PM   #317 (permalink)
tuskenraider's Avatar
Mike, is the swaybar swap pretty much the same procedure as the old models? As in removal of subframe and all that(which is the way I did it on my 05) or can you thread it through? I had ordered the 24mm FSB from JSC and for endlinks they only had the spherical as an option, which I wasn't interested in. Looking in the WL catalog it seems the WL heavy duty endlinks I've been trying to sell and almost sold today fit the 08-09's as well according to the catalog. Any reason you went with a noisier spherical setup? Less flex?
BTW, my Kartboy shifter and bushings came today and I had a hell of a time getting the shifter to pop in. I had to put a lug nut on the knob threads and stuff a wrech underneath the bottom of the car where it mounts to prevent any flex and whack it with a hammer while my uncle used a pry bar to further leverage it........ Man I was sweatin', waiting to f up some interior piece while hammering away, but got it done unscathed. I need to stop hi-jacking your thread lol and create my own, but that's not my thing. Just needed to vent.
And while I'm still going, Oakos sent me an Enkei catalog that shows a new RPFI TypeII wheel. Weighs a touch more the RPF1 and costs a little more as well, at least here. Definately looks better IMO.
tuskenraider is offline   Reply With Quote
Old 02-12-2009, 06:42 AM   #318 (permalink)
Moderator
same install process, except you'll notice that the "subframe" is tiny (four bolts) so it's a lot quicker install
the links I made up are thus far dead quiet- I believe it's the quality of the rod end that makes a difference- my guess is that the outfits making spherical links are not using top end rod ends.
Clearly a cost issue- mine were over $100 to make a set!!!!
Yes- less deflection AND adjustable for length which allows all pre-load to be taken out
I got the STi short shifter as an option this go around- the previous two I had to install myself- nice not to have to do that
ohhhh- that is a nice looking wheel! at 16.2 your still shedding over 7 lbs/corner (the 08/09 rims are heavyyyyy)
__________________
Old 02-12-2009, 08:30 PM   #319 (permalink)
wrxstar's Avatar
Quote:
Originally Posted by mustangtx63 View Post
I just installed said gauge about a month ago, and I love it! I removed the stock lamco gauge and installed the omori in its place so I could have more useful units for measuring boost.
Can you use the stock wiring from the stock boost gauge for the omori or other aftermarket gauge? I'd love to replace the stock one if I could use the existing setup.
__________________
03' bugeye, helix up, invidia DP, eibach springs, cobb stage 2
wrxstar is offline   Reply With Quote
Old 02-13-2009, 06:32 AM   #320 (permalink)
05Wrex's Avatar
Location: In the middle of a corn field somewhere in Illinois
Quote:
If you run a mechanical boost gauge you can. An electric boost gauge would require you to run more wires.
__________________
OBP 2005 Wrx - Big 16g
05Wrex is offline   Reply With Quote
Old 02-13-2009, 07:10 AM   #321 (permalink)
Moderator
bump stop update
just visited w/ RE Suspension- they actually tracked down the original manufacturer of the oe stops (my guess is there aren't too many) and were told they could produce several variants using the oe shape
he said to give him a week or so for them to get back, plan B is they have several stops they carry of the right length (varying durometer) and that they could drill out the stops to match the oe ones for ID
they "squeezed" the oe stops but if we go to plan B they'll re-squeeze it as all of their dyno plots are done in a bump cup- so it's an apple to apple comparo they'll have to test mine in a cup as well
bump cup
__________________
Old 02-13-2009, 11:48 AM   #322 (permalink)
Brack's Avatar
just read all 22 pages
__________________
09 WRX 5 door
DGM
Surgeline tuned w/bolt on's
Brack is offline   Reply With Quote
Old 02-13-2009, 01:00 PM   #323 (permalink)
mustangtx63's Avatar
You can reuse the stock vacuum line for the pressure, but you're going to have to connect a few wires. The wires from the stock gauge will not work. There is a great writeup in the diy section of j-spectuning.com that tells you everything you need to connect.
__________________
Blobeye Syndicate #063
PROtuned Cobb Stage 2
mustangtx63 is offline   Reply With Quote
Old 02-13-2009, 03:29 PM   #324 (permalink)
Moderator
Quote:
Originally Posted by Big Sky WRX View Post
decided I would go the spartan route for the interior
actually the bits are going to be shipped off to these guys- they are going to replace the vinyl boots, re-do in leather and stitch in a matching red thread
- JPMCoachworks | Automotive Redesign Studio - Genunine Alcantara, Suede and Leather Products, Services and Complete Interior Design
this looks better than the spartan look- the boss agrees
she also agrees leather > vinyl
thanks to Alex at jpmcoachworks!
__________________
Old 02-13-2009, 04:24 PM   #325 (permalink)
Hmmmmmm......black leather with red stitching, very nice....but both work for Valentine's Day for me! Oh, the car, right.......leather looks better!
Old 02-13-2009, 05:07 PM   #326 (permalink)
this car looks really intense. i like it
seapuss is offline   Reply With Quote
Old 02-14-2009, 11:41 AM   #327 (permalink)
BOOOSTIN's Avatar
Here ya go Big...it's a perfect match although my gauge looks
a little orangie on the pic.
It wouldn't be a bad idea to do a DIY boost gauge install for the 08/09's
__________________
****PHOTOSHOP SKILLS THAT PAY THE BILLS****
BOOOSTIN is offline   Reply With Quote
Old 02-14-2009, 06:17 PM   #328 (permalink)
Moderator
^ thanks for posting that
I'll do a write-up when I install mine- just have to make my mind up which one
__________________
Old 02-15-2009, 04:41 PM   #329 (permalink)
Moderator
cubby light
the 09 (08 too I believe) has a little "cubby" light that comes on w/ the headlights- I thought it was strange that basically everything is backlit in red and then here was this little cubby light in blue.
turns out the STi uses a red light and it's a easy plug and play
part was under $10- here's the # (the light pictured is the one that came out- the one that went in looks identical except the plastic housing is brown- and the light is red )
I had a clearer pic w/ a flash, but it washed the red light out completely- fuzzy but you get the idea
__________________
Old 02-15-2009, 08:25 PM   #330 (permalink)
wrxstar's Avatar
That's exactly what I was looking for. Thanks!
__________________
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
You Rated this Thread:
