cleaning engine w/o using hose?
Results 1 to 15 of 20
This is a discussion on cleaning engine w/o using hose? within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; allright guys ive tryed hosing out my engine but it wouldent start for about 3 hours is there any other ...
    Registered User a$$es of fire's Avatar
    Jun 2005
    Or
    allright guys ive tryed hosing out my engine but it wouldent start for about 3 hours is there any other way of cleaning out the engine compartment w/o using a hose?
    " Burton is like sex in the snow, only board shaped and not as cold" - Lizz ----
    Registered User WRXTwiztid's Avatar
    Mar 2004
    "i live with me wife and tree kids" IL
    dang how much water did you use?, i used a pressure washer on really low, and it cleaned mine perfect. with out damaging anything.
    05' WRB STI
    MODS
    Go raibh tú leathuair ar Neamh
    sula bhfuil a fhios ag an diabhal go bhfuil tú marbh
    May you be a half-hour in Heaven before the devil knows that you're dead.
    "sitting in the corner in Rick Roll timeout" chanwahyaoh's Avatar
    Mar 2004
    Detroit
    try not spraying water directly into the intake or fusebox
    Turtles are nature's suction cups.
    .____
    ||J || R.I.P.
    ||__||
    |/__\|
    Jun 2005
    Or
    i dident like drench i just used a pressure nozzle on my hose at a ligher pressure and i was careful about not hiting fuses air intake and i dident see a computer anywhere im guessing it has something to do with the wires leading to the sparkplugs like mabey water got under them i dont know but is there any other way to clean it?
    Registered User WRC_Obsessed's Avatar
    Jan 2002
    Boston/NNJ
    You can try using this too and wash with a towel.
    -Brian
    Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
    Aug 2004
    Woodinville, WA
    Lightbulb
    You also might want to check your distributor cap to see if any moisture got in there. It would be a no go if there was a drop in the cap. If this is the case, you can dry it out or make it a good time to replace the rotor and cap...
    JGT
    Registered User Wade-0's Avatar
    Dec 2002
    Southern Orygun
    Quote Originally Posted by THEOwrxwagon
    So where exactly is the distributor cap on a WRX?
    Jun 2005
    Or
    no the wrx dosent have a dist. cap good idea though. I just tryed the simple green automotive an di gotta say it really dose the trick thx for all you who gave me your .02 cents.
    Apr 2004
    Southeastern PA
    I have washed the engine bay of my last four cars countless times using a garden hose with no problems at all. Maybe you have some wiring / electrical problems? A gentle spray is all that is needed.
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Keep the car running while rinsing the engine, then keep it on for another 20 minutes or so afterwards (or even better, drive it around). You should have no problems doing it that way as long as you don't spray water into the air intake.
    BTW...if you just keep up with the dust/grit on a monthly basis, there should never be a need to was your engine off unless you are off-roading it.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Dec 2002
    Southern Orygun
    Quote Originally Posted by 04.SPT.WRX
    I also thoroughly hosed out my WRX and my wife's RS (which actually DOES have a distributor) last weekend and they both started right up, no problem. I used the Oil Eater stuff from Costco and it worked great. I read that Simple Green can stain aluminum, so I decided to pass on it.
    Jan 2002
    Boston/NNJ
    Quote Originally Posted by YBNormal07
    It is so hard in the winter months though.
    -Brian
    Aug 2003
    Richmond, KY
    I have had a lot of luck using a cleaning gun hooked up to my compressor. It mixes the solution with the air and just blows it right off. And b/c it is so small and compact you can target really small nooks/crannies and not hose the whole thing down.
    Jun 2005
    Or
    are you taking about an air compressor or a pressure washer?
    Aug 2003
    Richmond, KY
    Air Compressor. I found this neat little blow gun/cleaning wand that lets you hook up a tube to the cleaning solution and the compressed air mixes with it automatically. It is very similar to using a pressure washer but much easier to manuver around the engine compartment, offering mroe control. I tried my pressure washer which has a similar hookup where you can mix the solution but the wand was too big and even on low the thing just put out too much water and was a lot messier to use. This blow gun uses more air than water to blast way the crap and I have just found it easier to use.
