Installation of a crank pulley is cake. Remove the black plastic intake piece that covers half of the radiator. Remove all drivebelts. Put the car in 5th gear with the e-brake on, and use a breaker bar to remove the crank bolt. Wiggle the old pulley off making sure you dont lose the key when you finally remove it. Coat the end of the crank with a little oil and reverse the procedure.
LinkBack URL
About LinkBacks
