Originally Posted by jojotherider
There should be no leaks, especially from a bosal, that is the stock peice on the 2005 now, with a single tip from SPT. Did you need a new gasket there? The goofy looking peice of lead? Did you remember to put that back on? But yeah an exhaust leak just gets worse as it works its way out... so take it off and put it back on, make sure all lined up, gasket in place, and tighten down all the way, even though those springs dont seem like you should, tighten as much as you can, use the stock bolts if possible too!!!
LinkBack URL
About LinkBacks
