Results 1 to 2 of 2
This is a discussion on installing elbow. need help!!! within the Engine Performance forums, part of the Tutorials & DIY category; ok so i unscrewed the screws and poped everything out for the fenderwell. i see the stupid oversized stock silencer... ...
    Dec 2004
    ok so i unscrewed the screws and poped everything out for the fenderwell. i see the stupid oversized stock silencer... but i cant seem to unscrew the bolt holding it. i cant even fit my wrench in there or into the engine bay. how in the world did u guys unscrew it. i think im the only one who had this problem?
    Registered User dielectric's Avatar
    Mar 2003
    Palatine, IL
    I used an 18" socket extension with a swivel joint at the business end. If you had an air ratchet, that would probably work too. IIRC, there isn't room to swing a wrench up there, and you can't see it anyway.
    ribonucleic acid freakout
