Crank Pully Install?
Results 1 to 15 of 17
This is a discussion on Crank Pully Install? within the Engine Performance forums, part of the Tutorials & DIY category; Anyone have a tutorial for a lightened crank pulley?...
    Registered User hellafastWRX's Avatar
    Sep 2003
    Huntington, Long Island..... NY
    --Chris
    2011 DGM WRX hatch - Kartboy SS
    04 WRX wagon - 304whp Mods - SOLD
    LISC #3
    www.longislandsubaruclub.com
    Registered User WRXreX's Avatar
    Mar 2002
    NY
    try search at nasioc.com or clubwrx.net or scoobymods.com
    I installed mine in about an hour. You don't need any special tools, but will need one person to apply on brake while you break the crank pulley bolt loose...
    Tim
    Registered User Wrinkleboi's Avatar
    Jan 2002
    Langhorne, PA
    the brake doesnt do anything... learned that myself two nights ago. just put it in 5th gear and it will only have a little play in it.
    bryan
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
    www.TriStateTuners.com
  5. #4
    Registered User wake2snow5's Avatar
    Jan 2004
    Ellensburg, WA
    There is a shortcut which may not be safe to do, but it worked for me. I found it on the forums a long time ago and did the install a long time ago so you may want to look it up first. It involves cranking the engine for a second to break the nut loose on the crank pulley. Have someone in the front of the car holding the nut with a breaker bar or something long enough to hold onto without having your hand by the other pullies and have the other person crank the engine for a second. It worked like a charm for me.
  6. #5
    Sep 2003
    Thanks guys... I will continue searching. I ordered a Cobb pulley
    --Chris
    LISC #3
  7. #6
    Jan 2002
    Langhorne, PA
    pull the fuse for the ignition if you use the method above. however, its really not necessary... just get a nice breaker bar and dont hold back .
    bryan
  8. #7
    Administrator
    May 2003
    Bryan is correct. The easiest way is with the car in fifth, e-brake on, and using a breaker bar or extended 1/2 ratchet. A pipe on a ratchet will also work if you don't have the correct tools.
  9. #8
    Sep 2003
    sounds like fun.... I am going to have help from a guy I know who has a shop near me where they turbo V-TEC's. He said its easy.
    ps: your avatar is awsome
    --Chris
    LISC #3
  10. #9
    Administrator
    May 2003
    Quote Originally Posted by hellafastWRX
    Thanks Hobbes rules
  11. #10
    Jul 2004
    Indiana
    How about the re-installment of the aftermarket crank pulley? The specs calls out to torque it down to 98 ft-lbs. Any suggestions..... let me guess, a longer breaker bar.
  12. #11
    Jul 2005
    What about matching the torque specs? It has to be between 91-94 I hear, but how the hell will I know how much torque I am putting down. Is this reall a smart mod to do by yourself? My friend did his on another car and tightened it too much snapping the bolt. And I dont want it to be too loose? So what do you guys think?
  13. #12
    Administrator
    May 2003
    Quote Originally Posted by webster
    Use a torque wrench to measure torque.
    If your friend snapped the crank bolt, he was REALLY tightening it.
  14. #13
    Jul 2005
    thanks
    Yeh Im tryin to find one. Thanks.
  15. #14
    Administrator
    May 2003
    This one will work just fine.
    http://www.sears.com/sr/javasr/produ...id=00944595000
  16. #15
    Jul 2005
    LOL sweet.
