Crank Pully Install? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
This is a discussion on Crank Pully Install? within the Engine Performance forums, part of the Tutorials & DIY category; how the hell do i get a sick chewing animal avatar!...
    Aug 2009
    woodbury mn
    Jun 2010
    santa fe,Tx.
    I'm just posting this for future reference,but I just installed the cobb light weight pulley. This forum helped a bit but left out a bit. Tools I used were 1/2" drive breaker bar I believe it was the 24". Strap wrench 22mm socket, and a trust worthy friend. To remove I used the engine bump method. First I removed both accessory belts, and the plastic air scoop (not sure what its n once allame is)so once all that is out the way put the breaker bar on the bolt for the pulley, make sure you or your friend is strong because the engine will take you fort a ride if you don't hold that breaker bar in place. As a side note don't lean on any hoses for your power steering if you happen to do this,youll end up needing to flush the system later. So now, you or your friend needs to bump the engine. Ifsuccessful the bolt will be loose take it the rest of the way by hand. I had to bump the engine twice. To put the new one in place the pulley in position, hand tighten the bolt. Now get your strap wrench, wrap it around the new pulley and you can use the alternator pulley for resistance. Have you or your friend hold the strap wrench in place, as so it will not come free from where it is now wedged and the other tighten the bolt. I did not torque it to specs as I do not have a torque wrench. After you test drive you may want to retighten this bolt. The heating and cooling process may loosen it a bit. I am no mechanic but this worked for me.
