Page 1 of 11 12345678910 ... LastLast
Results 1 to 15 of 158
This is a discussion on STi intercooler sprayer within the Engine Performance forums, part of the Tutorials & DIY category; I'll try and walk you through installing one version of IC spray system. First I need to acknowledge my friend ...
    Jul 2001
    Plains of Eastern Montana
    I'll try and walk you through installing one version of IC spray system. First I need to acknowledge my friend Steve (300Z TT!) who w/o his electrical knowledge I'd still be staring at the pretty parts.
    First parts need for this particular install. I used a dual pump washer bottle (one pump to run the windshield wiper fluid) the other for the IC sprayer. These are oem on the WRX wagon as well as other Subaru models- you may be able to find one used. Next you need some washer hose- sold in 6' lengths at almost all car parts stores. You will also need nozzles- I used the oem STi nozzle (mine only utilizes one as it is a RA splitter). You need a switch- I used a STi oem switch- the manual one. You also need some wire and four female spade ends to fit the spade ends on the switch. They are small and may be difficult to find- I found mine at a Chevy dealership looking through boxes of connectors.
    First you need to remove the old washer bottle, two 10mm bolt heads, the plugh in to the washer pump and remove the hose leading ut of the unit- fluid will come out after you remove the hose.
    You can mount the new one in, reconnect the washer line and add your own hose to the second pump. You'll see there is a second plug in already there for the second pump. Note the colors of the wires- yellow/black and green/red on the washer pump plug and blue/black and white/orange on the 2nd plug.
    Jul 2001
    What we'll be doing is cutting the blue/black wire and splicing it into the yellow/black on the washer plug. In addition we'll be cutting the white/green and adding wire to it- sufficient enough to run into the cab via the gromett on the drivers side floor.
    Here's a rough outline of what we'll be doing:
    Jul 2001
    cutting the blue/black wire, you can also see the white/green cut w/ added wire (that one gets routed into the cabin). All connections were soldered and taped.
    Jul 2001
    Splicing into the yellow/black wire:
    Jul 2001
    We need two ground wires, this is what we did:
    Jul 2001
    We also want the switch to be lit when the headlights are on, so we tap the viloet wire in the next switch over - the cruise switch. We cut a splice into the violet wire and a add a short length of wire to it. Add a spade connector and it will go on the back of the switch as diagramed above.
    Jul 2001
    wire added to splice:
    Jul 2001
    here's ablurry pic of where we grounded the two ground wires- behind bolt head:
    Jul 2001
    Pic of the wire that we ran in from the engine bay (the white/green wire). Also can see the wire we added (spliced into) the violet wire:
    Jul 2001
    Next we install the switch into the blank and refering to the diagram hook up the wire from the engine bay (originally the white/green) to manual trigger position, the wire that is spliced into the viloet wire, and the two ground wires:
    Jul 2001
    Mount your nozzle(s) -there are already oem cutouts for the nozzles on the STi splitter. Make sure you face them the right direction. Steve gave me a good blast in the face on a test .
    Pic of nozzle:
    Jul 2001
    I just routed the hose paralell to the existing hose- like so:
    Jul 2001
    Pic w/ switch installed. Now when you need a little cool down, just give the button a push- it will mist as long as the button is held in.
    Nov 2003
    Montana
    Glad I could help. Nice write up Mike!
    Apr 2003
    CT
    Where is a good place to get the switch and the harness plug?
    '12 WRB Sedan
