STi intercooler sprayer - Page 5
Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 61 to 75 of 158
This is a discussion on STi intercooler sprayer within the Engine Performance forums, part of the Tutorials & DIY category; Does the WRX have mounts for the USDM STi tank in the trunk?...
  1. #61
    Apr 2003
    CT
    '12 WRB Sedan
  3. #62
    Jul 2001
    Plains of Eastern Montana
    My 02 doesn't that I've seen, although I'm not exactly sure where the v8 mounts the ic tank.
  4. #63
    May 2004
    College Park
    Thanks for all the info. I have been waiting for this install for a while. As far as a harness Subaru doesn't sell the seperate parts. In order to get that little section they make you purchase the ENTIRE harness. What I plan to do, instead of individual leads, is to visit the junk yard and get the harness that goes into the Cruise Control or Fog Lights button. I've tried them already and the fit snug as a bug. I just have to make sure that I get enough wire with it to tap in according to Big Sky's diagram.
    Thanks again,
    Todd
  6. #64
    Jul 2001
    No problem- welcome aboard!
  7. #65
    Registered User Wrinkleboi's Avatar
    Jan 2002
    Langhorne, PA
    bump... going to give it a shot now. i'll take pics if i think there are any other helpful ones and let you know how it goes.
    o-|-<) bryan
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
    www.TriStateTuners.com
  8. #66
    May 2004
    College Park
    Hey everyone,
    I hit the junk yard today and found very few Subarus. Damn them for making such a quality car. Anyway, I happened upon an early 90's Legacy and sure enough the cruise control switch harness and fog light switch harness fit perfectly. I installed tonight and everything looks super clean. Thanks again for the help.
    Todd
  9. #67
    Mar 2004
    San Antonio
    I installed this to my FMIC, but the only problem is that when I turn it on it keeps syphoning the water even when its off, causing it to drip out of the hose. I tried using a connector to prevent that from happening, but even with the connector it still drips. Is there a better connector that will prevent this?
    BIGGER IS BETTER!
  10. #68
    Jan 2002
    Langhorne, PA
    there must be some sort of sealed valve thta you can use which which will allow water through when it is under pressure, but it will seal off once the pump stops working. dont know where to find it, but thats what you want to be looking for.
    o-|-<) bryan
  11. #69
    Sep 2001
    Edmonds, Washington
    One way check valve would probably solve that. I'm sure you can find one that cracks at ~1-2 psi that would prevent the siphoning.
    http://homepage.mac.com/supermarkus/PhotoAlbum1.html
    Mullet haiku:
    Daughter's BMX
    Takes me to welfare office
    Trans Am is on blocks
  12. #70
    Sep 2001
    Edmonds, Washington
    I'll confirm this, I don't have the mounts in my trunk either. I may have to fabricate some, I just haven't put much time into the car lately.
    Mullet haiku:
    Daughter's BMX
  13. #71
    Registered User PKer's Avatar
    at work
    The V8 STi reseviour mounts to the tunk on the opposite side of the jack.
    If anyone has found a check valve that will work, please post the details.
  14. #72
    Mar 2004
    San Antonio
    Yeah I know that's the problem I'm having with my STI tank (larger one against back of seat) is that I need a check valve. The one's that I've tried don't seem to work. Any ideas anyone?
    BIGGER IS BETTER!
  15. #73
    Jan 2002
    Langhorne, PA
    subaru sells them, and mine is working great so far. the label says:
    Valve Sub-Assy, Wash 786634050
    o-|-<) bryan
  16. #74
    Mar 2004
    San Antonio
    So those are check valves for the actual STI intercooler sprayer? Hmm, guess I could go and try those. Just hope they work for my setup with FMIC. Thanks, RYAN
    BIGGER IS BETTER!
  17. #75
    Jun 2004
    San Diego
    can someone plz tell me which one of the switches to tap for + cause i did everything and i'm using a rocker switch and i think i need a positive wire to tap but i don't know which one, n e help is appreciated. i have an 03 wrx.
