STi intercooler sprayer - Page 2
Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 16 to 30 of 158
This is a discussion on STi intercooler sprayer within the Engine Performance forums, part of the Tutorials & DIY category; Rallispec sells the switch The harness plug (if your talking at the washer bottle) is already there- unused (unless you ...
    Jul 2001
    Plains of Eastern Montana
    The harness plug (if your talking at the washer bottle) is already there- unused (unless you have a wagon).
    Apr 2003
    CT
    Thanks for the info, I meant the white plug that plugs into the back of the switch, does it also come with that?
    -Dave
    '12 WRB Sedan
    Registered User PKer's Avatar
    at work
    The white part is part of the switch you don't get the other side (harness) it is part of the OEM STi cluster harness.
    You have to use small wire connectors to wire the switch.
    If you don't have an STi splitter do what I did.
    Home Depot has the nozzles called "Pot & Basket Misters" they are as good as you are gonna get from there (trust me I tried several), get them.
    Your stock WRX scoop seal (rubber part hanging down) is held on by little button type clips, take the two front top ones out, drill just a tiny bit to widen the hole, and put the elbow that came with the "Pot and Basket Misters" through those now widened holes. Attach the misters to the inside (duh) and the water supply hose to the out side of the elbow, aim the misters and have spraying fun!
    Note: if you drill correctly the clips will still go back in if you remove the water spray system.
  6. #19
    Registered User dudical26's Avatar
    Jun 2003
    what size spade connectors did u use.....do u have a link where i can get them.
    Thanks
  7. #20
    Jul 2001
    Thanks
    I got my by luck. I tried our local radio shack and they didn't have anything (it's a small one). I went to a local Chevy dealership and we went through several boxes of connectors and I found four that fit, but no part # unfortunately.
  8. #21
    Jul 2001
    READ THIS IMPORTANT
    I just found out from another fellow who did this last night, there is evidently a much easier way- the white/green wire has power- you can leave it be, the black blue you can leave be at the plug in as well. No need to cut at the plug in at all!
    No need to run a wire into the cabin either. What you'll have to do is pull the front piece off the steering column and near the ignition you'll find the blue/black (same one as at the plug end), cut this wire and expose ~ 18" or so to reach the switch. Put a connector on the end of this and put it on at the manual trigger.
    The illumnation/ground remains the same.
    This makes things quite a bit easier.
    Big Sky
  9. #22
    Registered User MK19's Avatar
    Jan 2003
    Plantation, FL
    I used a 2004 STi I/C tank and wired it up to a STi manual spray switch. The only difference is that the pump is wired as such:
    Positive to a switched hot (positive) power source and the ground (negative) goes to the switches manual trigger. Sweet is all I have to say
  10. #23
    Jul 2001
    What's the STi tank hold if you know? Also where did you mount it? I know the spec C goes w/ a mega 12l tank that mounts in the trunk- that would last a track day!
    TIA
    Mike
  11. #24
    at work
    They USDM STi tank is behind the backseat and of giganto proportions. The problem is you have to get a new trunk liner as well.
    Well maybe you don't "HAVE TO" but it wouldn't look as nice.
  12. #25
    Jul 2001
    I didn't think the STi (USDM) one was too large, the spec C goes across the entire width of the trunk and is 12 liters- I'd be curious what the US STi one is. I'll get a good idea on how long my wiper bottle lasts this summer.
  13. #26
    at work
    12 liters is large compared to my 2 liter bag reseviour.
    You're right the STi does go across the whole trunk, behind the back seat. You lose the pass through and would need to alter your existing trunk liner or get an STi one.
  14. #27
    Jul 2001
    There two distinct sprayer tanks the USDM is smaller than the spec C one
    pic
    The RA is 12 liters, definitely bigger, but uncertain by how much. It's possible the US one is right inbetween the wsher bottle size and the spec c one
    pic of spec C
    Big Sky
  15. #28
    Mar 2004
    nj
    so what did you use for the switch? the black connector behind the dash just chillen?
    or something else?
  16. #29
    Jul 2001
    or something else?
    You buy an STI switch- plugs right into the existing blank you have- then wire according to above. The connector that is wired back there is for something else- waht I couldn't tell you.
  17. #30
    Mar 2004
    nj
    where was the connector you used?
