Just spotted this one, which may be of interest to those doing this mod. Pricey though...
This is a discussion on STi intercooler sprayer within the Engine Performance forums, part of the Tutorials & DIY category; I have an 06 TR I'm gettin ready to do this mod and have amassed my parts but want to ...
I have an 06 TR
I'm gettin ready to do this mod and have amassed my parts but want to iron out the electrical before i start. I dont have the factory fog lights, is there a way I can use that plug to plug into my sti switch or are they different? If they are different can I utilize that circuit since it is connected to the factory fuse box and relay? If so where are the wires under the hood and what do they look like?
The terminals that fit the back of the sti switch.
Heres my post.
06 TR Intercooler Sprayer DIY (56k go away)
I just did this on my wagon.
Right now it's lame-style until the switch gets here, but I just went to the hardware store and bought some 1/4" tubing and some sprayer T nozzles, unhooked the plug for my rear wiper so it wouldn't move when I hit the rear window spray switch, mounted everything up and it works like a charm.
Just wanted to let you guys know that if you really want to do it, it can be done (on a wagon at least) for 6 frickin dollars. Definitely not a bad mod for the price.
nice cheap mod![]()
Orange cones fear me.
getting ready to do this mod. 1 quick question. my washer bottle is filled with windo washer fluid. is it ok to spray that fluid on the ic or should i dump it out and use water?
and
if you have a wagon a do this does it mean every time you press the ic button water will shoot in the ic as well as seep out on the back window??
-Dan-
Bugeye Mafia #158
I would change the fluid for water, NJ gets kind of cold though, so you might have problems in freezing weather.
You won't have any water on your rear window because you disconnect the hose going back there to hook up the hose for the sprayer. I only use mine for autocross, spraying between runs, so after next weekends finale I'll hook the rear washer hose and the electrical connection for the rear wiper back up for winter use.
Hawk-Eye Alliance #001
The Tranny Fluid Thread | HAWK EYEs | 06 Clutch change | 06 timing belt | DIY wooden wheel stands | DIY Alignment
06 WRX TR
nice thanks guys
-Dan-
Bugeye Mafia #158
So I hope to start gathering parts to basically do this "mod". In actuality most of the harder stuff is already done, the I/C sprayers and the like. Its just that the I/C sprayer hose was taken straight off the windshield misters then rewired to an on/off switch. So I hope to get a second pump and reattach the windshield misters to the correct button. I'm also more of a purist and want the subaru I/C sprayer switch instead of the on/off one. I hope to get the parts tomorrow and do some-most of it. We'll see how it goes!
Just finished this!!! I still haven't got the Subaru switch though. Does anyone know if you can wire up the five second timer to be manual? push=spray, release=no spray. I know this thread is old but here's hoping someone is reading this.
Any way to keep wipers from running when you spray washer fluid? if so why couldnt you just reroute the washer lines and mount new nozzles inside hood scoop
keep your eyes out on ebay too i found a whole set up including the switch, lines, and tanks used for 50 bucks
i live my life a 1/4 mile at a time
