Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on knife edging throttle body and gasket matching the intercooler intake pipes within the Engine Performance forums, part of the Tutorials & DIY category; When I do the butterflies I use good old hand files. You have better control. With a good hand I ...
    Aug 2002
    Roanoke, VA
    When I do the butterflies I use good old hand files. You have better control. With a good hand I found it gives a more even/smoother transition. Then I polish it out with some wet sand.
    FYI: There's a raised lip around edge of the butterfly. Since you have it off, flat sand it. Plus it makes it shine
    Quietest Cobb Stage 2 in the world. Throttlebody's by WRX03. I/C hoses and ported elbows. Daddy's DP with stock heatshield. 3CE with stock heat shield. Stock catback. PnP Turbo.
    Wife drives it, too fast
  2. #17
    Jul 2001
    Plains of Eastern Montana
    Nice, I see you also did the butterfly shaft as well. I think it was from your post that I got the button head screw info from- it worked perfectly- just the right length.
    Big Sky
  3. #18
    Registered User Speedstars's Avatar
    Mar 2003
    Since I'm not familar with throttle bodies, what did you use to clamp or plug up the coolant hoses? Do you have any problems with getting air into the coolant? I'm guessing you just unwind the throttle cables to get them off? Is that all there is to it besides the bolts?
    Drifting away...
  4. #19
    Nov 2003
    Dayton Ohio
    All you do is disconnect the coolant lines, they'll leak a little but not much. The air that gets in isn't going top hurt. I din't have to plug them as I just pushed the hoses around till the tips were up and let gravity do the work.
    Hold the throttle open with your hand then removal of the cables are self explanatory. Just look at them you'll see.
    Your Friendly neighborhood Antimullet
  5. #20
    Registered User Orbit's Avatar
    May 2003
    TdO4 12.4@109
    here are some I took berfore during and after.
