But I'm not sure where the ports are. If anyone could help me out with that it would be awesome. Thanks.
This is a discussion on Grounding Mod within the Engine Performance forums, part of the Tutorials & DIY category; Originally Posted by bolinp78 I put in 7 ground wires (including a tranny one) into my G35 coupe and didn't ...
it all revolves around creating a cleaner electronic environment. if you can ground the components better, they will operate more efficiently. granted, it may be an extremely small percentage of said effeciency, but its still there. some people tend to notice it more than others, and this might have to do with how well the car is wired in the first place... you don't need a HUGE gauge wire. all you need is an average size gauge (10 to 8 gauge should work great, not too big, but not small enough to snag and break). it should have ultra high conductivity and you should also wire brush/file/clean the frame to get perfectly clean connections to the grounding points. the huge gauge everyone is talking about is actually meant for high current, but for this type of grounding, its purely for looks.Originally Posted by bolinp78
Dave
01 RS
i'm curious as to what you expected to 'see.' on the cars i've done this to, i've noticed slightly better mileage, and a slightly smoother running motor. it just felt.... 'cleaner' overall. throttle response (on the Z, at least - obviously it'd have to be a drive-by-wire system) was a little cleaner and more accurate. but i wasn't expecting a kick in the ass boost in power or anything.
s e t h"If you're going to live on the cutting edge, you'd better be prepared to bleed a little."Stink-Eye Mob #73, Hawkeye Alliance #667
I have one on my car it's nice. I bought mine for dirt cheap from these guys. http://www.camotoy.com/
Dude...are you like the king of resurected threads...or is it just my imagination?
PS...www.worxtuning.com. They have a fairly inexpensive ground wire assembly that works well and is unobtrusive.
tEh PriUs=teH faSTah!@@!
306 AWHP/341 AWT, Stage 2
probably a little bit of both - came up in my mailbox from when i'd subscribed years ago, so i thought i'd answer again![]()
Glad you liked it Justin. I too noticed the smoother idle after installing this.
I'd put on on tEh pRIus but I'm afraid of the battery in it![]()
old a$$ thread, but i'm sure someone is still interested in grounding stuff and plus i'm stoked on my kit i got.
it's from Flex
they are fairly inexpensive, but when i got the kit...OMG...fit, finish and quality can't be beat!
i thought all this grounding stuff was bs but it's not. changes are subtle, but noticeable. i even got 1mpg better!
"Let the ingorance die with the ignorant"
