There are two ways to remove the uppipe.
One is to remove the turbo and take it out from the top. (What s/he did)
The other is to jack up the engine so it can be removed through the bottom. (What I did)
Jacking up the engine is no big deal, you loosen one nut, grab a block of wood, put it under the oil pan and jack it up a little. *shrug*
LinkBack URL
About LinkBacks
