Uppipe, Downpipe, Muffler INSTALL GUIDE! - Page 6
Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 76 to 90 of 172
This is a discussion on Uppipe, Downpipe, Muffler INSTALL GUIDE! within the Engine Performance forums, part of the Tutorials & DIY category; Thanks for the comments, any problems with the instructions, or did you have mostly eveything you needed?...
  1. #76
    Registered User tubbytreats's Avatar
    May 2003
    2002 WRX Mods:
    AP Stage2/93, ScoobySport Up, Dp, & Muffler, SS AutoChrome TMIC, Hawker PC680T Battery, Injen CAI, ACT Stage2 Clutch, Gruppe-S 13.8lb Flywheel, Mobil1 and Redline oil, NGK BKR7EIX plugs, Goodridge SS Lines, Motul RBF600, Hawk HPS pads, 35% 3M tint, Koji Headlight Mod, SilverStar Bulbs, Blaupunkt MP3000 headunit, Infinity BassLink Sub, Kenwood KFC-1689ie speakers (6.5"F / 5.25"R), Rota Downshift (Black), Yokohama AVS ES100 (225/45/17)
  3. #77
    May 2003
    bump
    2002 WRX Mods:
  4. #78
    May 2003
    Anyone else done this install recently and have issues that weren't covered in this DIY?
    2002 WRX Mods:
  6. #79
    Registered User KoreanBeefcake's Avatar
    Jul 2003
    Huntsville, Alabama (formerly WA)
    do you have to torque any of the bolts? if so which ones?
  7. #80
    May 2003
    Did you miss this "Subaru Torque Guide"?
    2002 WRX Mods:
  8. #81
    Registered User EvilCerealBoX's Avatar
    Nov 2003
    ATX
    Quote Originally Posted by tubbytreats
    what about the rest of the pipping torques?
  9. #82
    May 2003
    For the turbo-to-downpipe bolts, I just used similar torque to what is pictured as T3 in those pictures. (26 ft lb) For the midpipe-to-downpipe bolts (if you have a short aftermarket downpipe vs the long aftermarket downpipes), you should use the same T3 torque there.
    On bolts past the downpipe, your tightening torque is up to you. The most important torque figures are for the header, exhaust manifold, and uppipe. After the turbo, it is much less likely to have an exhaust leak as most people usually have uppipe leaks from improper torquing (or forgetting about re-torquing those bolts)
    2002 WRX Mods:
  10. #83
    Nov 2003
    ATX
    anyone know how to tell the difference between an 02-03 and 04+ cel fix?
  11. #84
    Sep 2004
    Hey, does the scoobysport ss1+ up,dp,exhaust keep a car emissions legal? Does it keep the midpipe cat? I live in dallas texas, the emissions laws are kinda laid back from what i hear...
    '03 Aspen white rex
    -Infinity Kappa Perfect 12D VQ running on a MTX audio 420D.
    -Kicker SS components (6.5") running on a hifonics saturn a4000
    -60 sq. ft of edead v1.2se
  12. #85
    May 2003
    tracker7821,
    Yes, a Stage 1+ ScoobySport Exhaust system with the stock midpipe cat in place should pass emissions. I have the same system on my car and easily passed OH sniffer test rules.
    There is a thread about it called "Passed OH Emissions" and I suggest you search for it.
    2002 WRX Mods:
  13. #86
    Registered User ynotajb's Avatar
    Sep 2004
    mmmm,, tater salad
    Put the 2x4" piece of wood on your jack and jack up your motor on the oil pan. (Am I crazy you are asking??) Yes.
    is this actually safe???? Not doubting you tubbytreats... i just would rather not mess something up on my brand new car...
    dude one time i tried to put the trailer bully into the coiler, and I got all messed up
  14. #87
    May 2003
    Well, you have (2) options:
    1. Jack up the engine on the oil pan after loosening the engine mount bolts.
    2. Remove the turbo and coolant/oil lines to get the uppipe out.
    Your choice, neither way is fun. After having countless 100's of folks jack up their engine this one time using the oil pan, it's probably just fine.
    2002 WRX Mods:
  15. #88
    Aug 2004
    Hey tubbytreats, do you have a picture of the rear of the car with the scoobysport exhaust. I am interested into seeing waht it looks when fully installed from the outside. Thanks.
  16. #89
    Sep 2004
    mmmm,, tater salad
    thanks tubby ... ill do it that way then ... thanks a lot for the great directions!!! i was kinda like this when i saw them ...
  17. #90
    May 2003
    bsbretly,
    You can see a shot of what the ScoobySport exhaust looks like installed by viewing the videos at the beginning of this thread. They have a good shot of the car at idle and you can see the exhaust on their test car at RallyPerformance.com
    Enjoy!
    2002 WRX Mods:
