Uppipe, Downpipe, Muffler INSTALL GUIDE! - Page 12
Page 12 of 12 FirstFirst ... 23456789101112
Results 166 to 172 of 172
This is a discussion on Uppipe, Downpipe, Muffler INSTALL GUIDE! within the Engine Performance forums, part of the Tutorials & DIY category; Originally Posted by mycologist Bumping a tutorial is perfectly acceptable. Yep, and this is a pretty good one. tubby's tutorial ...
  1. #166
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Yep, and this is a pretty good one. tubby's tutorial actually helped me get through my first DP install on WRX #1 in October of 2003.
    Wow, I was still a mid-30's guy then. Weird.
    --Ray
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
  3. #167
    Registered User BountyHunter's Avatar
    Sep 2010
    LBC
    just installed uppipe with this tutorial thanks tubby! i only ran into one problem and that was removing 02 sensor from manifold to get to uppipe bolts sprayed tons of pb but didnt help just went around 02 sensor and i did use a 02 wrench
  4. #168
    SPT for the win! lashak's Avatar
    Jul 2011
    Maryland
    is there an tutorial this good for the 06+ WRX? or would most of this be the same? i have not seen the need to remove so much of the engine in tutorials i have seen for the 2.5?
    Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.
  6. #169
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    That's because catless uppipes became standard on all WRXs from 05+. While there is some evidence to suggest an aftermarket uppipe might still benefit later years, it's no where near as beneficial to those cars as it is to the 02-04 cars.
    2007 Outback 3.0R wagon
  7. #170
    Registered User jestr's Avatar
    Feb 2013
    I really want to do this on my 2002 WRX, but I live in NY and I can't mess up the emissions. Does anyone know if you can still do this stuff and still pass inspection?
  8. #171
    Nov 2012
    Montana
    I saw your thread about you installing your uppipe, downpipe, and muffler and I have a few questions. I have a stock 02 WRX with nearly 88k miles on it. I've only had it for a year and am not super familiar with working on my car. Would you still suggest trying to install these if I'm not familiar with working on my car? I was not aware of the cat breaking apart and being sucked into the turbo. I definitely would like to replace that.
    Do I need to do anything else to my car if I installed an uppipe, downpipe, and muffler? Any tuning? Would you suggest a COBB accessport tuner?
    Thanks for the help!
    -Ryan
  9. #172
    Oct 2005
    Late Devonian
    This is not going to be beginner's work, especially on an older car. I'd say try doing just the DP first but you have to do the DP to get to the UP anyway. It is going to depend on if you can get the bolts loose without breaking any and if you can deal with jacking up the motor to wiggle the UP out. If you do it, use lots of PB blaster well ahead of time.
    On an '02 you can squeak by with no tuning on this, but you will be much better off getting a map as it will give you the benefits of the mods. really only after it is tuned. That is per the DP - the UP does not require anything.
