The resistor only works for the EGT in the up-pipe. The 02 sensors post turbo (there should be two btw) cannot be fixed in this manner. You have a couple of options though. 1. Most commonly reccommended. Get your self a Cobb Access port. Use it as engine management and use it to clear the check engine lights. 2 Get your self 4 18mm spark plug non foulers install them in the bungs where the o2 sensors go then reinstall the o2 sensor the sensors will be getting a smaller sample and not throw the check engine light. 3. There is another form of wire resister to use on the o2 sensor wires. I havent done much research on this so you can if you would like. Im typing this fast so I may edit later any questions ask.
LinkBack URL
About LinkBacks
How Fast Can You Afford To Go?
