turned up the boost
Results 1 to 3 of 3
This is a discussion on turned up the boost within the Engine Performance forums, part of the Tutorials & DIY category; I recently installed a boost controller, but am not getting the readings I expected. I tried to dial it in ...
    Feb 2003
    alabama
    turned up the boost
    I recently installed a boost controller, but am not getting the readings I expected. I tried to dial it in at 15psi and in 1st and 2nd it only reaches 13psi and then it hits 15 in 4th. any suggestions?
    Registered User racerWRX's Avatar
    Jun 2002
    steeltown
    with a mbc thats what will happen, higher the gear, higher the booost. only way to cure the problem is buy a ebc......
    you figure your best gear is 3rd and set the desired boost to max out in that gear
    have you ever been 4 bagged ???
    Apr 2003
    CT
    Correct! For the original poster, please read the MBC threads Good luck!
    MBC INFO [discussion, questions, guidelines].
    '12 WRB Sedan
