stock air intake has a silencer? - Page 2
Results 16 to 30 of 32
This is a discussion on stock air intake has a silencer? within the Engine Performance forums, part of the Tutorials & DIY category; Originally posted by jroman836 Craig, Remove the Ram Air Scoop and just plug the fender hole (where the scoop led ...
    Jun 2002
    Long Beach, CA
    Craig,
    Remove the Ram Air Scoop and just plug the fender hole (where the scoop led into) with this part: "Fender Well Blocking Plate" PN# 46059FA000. Five bucks at local Subaru Dealer. Its a stock part for the 99-01 RS.
    Thats what I did. Looks very stock. Keeps the hot engine bay air away from the fender.
    jroman836, how would the air go into the fender if you take out the ram scoop and plug the fender hole?
    Registered User AREITU's Avatar
    Oct 2002
    Originally posted by emily
    Does anyone by chance have a .mp3 or .wav of their car minus silencer? I love the rumble of my Strömung exhaust and wouldn't want to spoil the harmony... ..but more noise is almost always better
    I'm not mad for the air-brake sigh from BOVs - is the stock BOV much more noticable without silencer?
    The difference isn't dramatic like say a Honda with an intake vs a Honda without an intake. Your car might growl just a little bit more when you stomp on it. If you want a big difference, do the airbox hack.
    Most likely your exhaust will cover additional noise removing the silencer makes. And you'll hear something that sounds like a sneeze from the passenger side fender when you let off from full boost.
    Registered User Lightndattic's Avatar
    Aug 2003
    Dallas, Tx
    When I did this, I didn't completely remove the snorkus. I cut off the bottom portion (just below the ram air inlet) which takes a good 2 ft off the intake track. I kept the ram scoop on to look stock. It definately sounds deeper and with a K&N, it absolutley screams when at full boost. The BOV doesn't sound any different to me.
    03 Subaru WRX Sonic Yellow
    "The Short Bus"
    Looks like ****, Goes like stink.
  6. #19
    Registered User 04EJ25's Avatar
    Sep 2003
    Old Bridge, NJ
    Originally posted by bone324
    Probably. I think Subaru voids the warranty if you put gas in your tank, air in your tires, or miles on the odometer. That's just the way they are. Don't sweat it.
    HAHA! They will even void it w/ one of their own parts; a STi muffler!
    I just bought a STi!!!
    Love it!!!
  7. #20
    Registered User scoob's Avatar
    Nov 2001
    Columbus, Oh.
    Ok so what happens when you hit a major water puddle and splash water all over the place? Aren't you afraid of hydrolocking your engine?
  8. #21
    Sep 2003
    Old Bridge, NJ
    I think you can buy a plug that will keep H2O out. Anyone know about this???
    Love it!!!
  9. #22
    Nov 2001
    Columbus, Oh.
    I know there is a plug for the inner wall of the engine bay, but what about the rest of the area in the finder well? All I know is that I have seen pictures ofthe wrx going through water with water coming out of the air vents in the bumper etc. and I would feel very uncomfortable driving mine in rally-like conditions with the intake sucking right from the finder all out in the open like that you know?
  10. #23
    Registered User Vostok 7's Avatar
    Dec 2002
    Limehatless Avatar - I'm a trend scoffer.
    I just cut the "gallon jug" like thing off the intake on mine, so there's a big hole in the little U pipe but otherwise it's stock (I believe in the "snorkus" as I noticed differences between running just the airbox vs. the airbox with the snorkle).
    And I've done this:
    BUGEYE 4 LYFE! Or uh maybe not
    RIP Team Intrinsic Viva la Project 1! http://www.prjct1.com/
    2003 Subaru Impreza WRX Sedan 4EAT Aspen White "Akane"
    Mod List, Picts
    2004 Subaru Impreza WRX STi Sedan Aspen White "Akane II"
  11. #24
    Sep 2003
    Old Bridge, NJ
    I flooded a Jeep once. She never ran the same, but it looks like Vostok has the right idea...
    I just got my car back from the shop. I went to COBB's Stage 2 with a Perrin DP. Using my G-Tech I just ran a 13.7@101MPH in the rain! It looks like I'm up from 195HP to about 220HP. COBB has it listed as 224HP on their chart with a full turbo-back, so I think I'm close to true numbers being that I only did the DP and the only other mod I have is a Perrin Uppipe...
    Love it!!!
  12. #25
    Nov 2001
    Columbus, Oh.
    Good job guys, I'm imprezzed!
  13. #26
    Nov 2001
    Columbus, Oh.
    Vostok,
    Are you saying it's better to run the front snorkle with the airbox and the resonator out, with nothing in between them? Sounds cool if so.
  14. #27
    Dec 2002
    Vostok,
    No, because the snorkle flops around since it's only held in by the two bolts on the radiator support.
    What I did was cut the gallon jug (the resonator/silencer) off the U pipe that connects the snorkle with the airbox, then put everything back togeather. It looks 100% stock, certainly doesn't sound it .
    I did however notice a difference in power application between having just the airbox and the snorkle/cleared U pipe/airbox. Maybe it was just me though.
    What I'm going to do now is get a U pipe from http://www.generationplastics.com/ which is almost exactly like the stock unit, without the resonator/silencer. It even has the same bolts so it bolts right up.
    Vostok 7
    Mod List, Picts
  15. #28
    Nov 2001
    Columbus, Oh.
    Good idea bro, just rememeber to put a drain hole in it!
  16. #29
    Sep 2003
    Old Bridge, NJ
    Thanks man!!!
    Love it!!!
  17. #30
    Registered User InfamousDX's Avatar
    Jan 2003
    Bergen, NJ
    You just don't get on the throttle through the puddle so you don't suck air/water in.
