Samco I/C hose installation on WRX with PICS! - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 49
This is a discussion on Samco I/C hose installation on WRX with PICS! within the Engine Performance forums, part of the Tutorials & DIY category; what a whimp the BOV hose is a bast-ard, the clamp on the turbo side is upside down and will ...
    Aug 2002
    Cleveland, OH
    what a whimp
    the BOV hose is a bast-ard, the clamp on the turbo side is upside down and will cause MUCH cussing
    Feb 2003
    New York
    Where can I find info on that hose kit?
    How much did u pay for the whole thing?
    Banned jedimaster's Avatar
    Jun 2002
    Nice instructions, but you forgot to include what itmes you need to remove- you say remove the following, and then show the entire engine bay.
  6. #19
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    Thank you very much for the very detailed descriptions and pictures. Just what we need at this club. Very informative.
  7. #20
    Registered User CustomS10's Avatar
    Nov 2002
    Western Mass
    in small red letters he has numbers on what needs to be removed. i'm guessing in what order also.
    -Ben-
    Spark it or Park it!
  8. #21
    Jun 2002
    Hmmm, you're right- couldn't see it on my crappy comp at work.
  9. #22
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    what's that black line on your intake manifold thats sitting just left of the throttle cables?
    Silver 911
    WRX's older brother
  10. #23
    Jun 2002
    Look closer.
  11. #24
    Feb 2003
    New York
    Ive heard that Samco Hoses need to be "trimmed" on the inside....did you have to do this? And if so, where and what needed to be removed.
    Thanks
  12. #25
    Registered User WRXreX's Avatar
    Mar 2002
    NY
    To be honest with you, effects of pieces that need to be trimmed are nearly negligible. Some vendors make such a big deal out of it as if it is a big deal. Takes 5 min to trim them off..
  13. #26
    Feb 2003
    New York
    Can you elaborate on what needs to be trimmed and why?
    Thanks.
  14. #27
    Jan 2003
    Pittsburgh, PA
    new install
    I just installed the samco hoses...well 2 out of the three. the third hose from the BOV was a pain because of the clamp. Is there a way to get that clamp off without destroying everything around it or cutting the hose? I am more than frustruated and need help. Thanks in advance.
  15. #28
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    I'll be installing mine tomorrow, so I will post up if I run into any trouble.
    Q: Does the "flash" inside the Y hose need to be trimmed? Does anything else need to be trimmed?
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
  16. #29
    Registered User BlkWRXWag's Avatar
    Jan 2003
    Trabuco Canyon, CA
    I got that clamp off by managing to get a pair of pliers on it and twisting it so the that top of the clamp is pointing upwards - then you can get a good grip on it with the pliers and squeeze.
    Aj - I just trimmed the flash with a utility knife, but be sure not to accidentally cut the main hose. If in doubt, I would just leave it.
  17. #30
    Aug 2002
    SoCal
    To move that clamp, use a good pair of NEEDLE NOSE pliers. They can really get in there.
    I'm not too worried about cutting the main hose. I used to build models so I have a pretty steady hand. I'm just curious if there is anything else that needs to be trimmed, and if the only flash I need to cut off is at the middle intersection of the Y hose.
