Results 1 to 15 of 21
This is a discussion on DIY: PCV valve replacement (pictures!) within the Engine Performance forums, part of the Tutorials & DIY category; Spent 30 min replacing PCV valve on my 2002 WRX today. Tools you need: 3/4" wrench 12mm socket & wrench ...
    Registered User WRXreX's Avatar
    Mar 2002
    NY
    Tools you need:
    3/4" wrench
    PCV valve from autozone: PN PCV1142
    First, you have to remove TMIC and it can be done by following steps I posted here:
    http://forums.nasioc.com/forums/showthread.php?t=964852
    Once TMIC is removed, please follow these 'simple' steps:
    Disconnect blow off valve recirculation pipe from BOV and pull it away so that you can reach PCV easier.
    Disconnect this hose (small amount of coolant may spill out)
    PCV is located here:
    Simply pull the hose away to expose PCV:
    Using 3/4" wrench, remove PCV:
    Mar 2002
    NY
    New PCV vs old PCV (35k miles)
    Old PCV
    Mar 2002
    NY
    Do everything in reverse order and you are all set! Enjoy your new PCV valve!
    Nov 2005
    Central Florida
    great write up
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Registered User PolarisSnT's Avatar
    Aug 2002
    Staten Island, NY
    You should note that the 2004s are different than the 2002/2003s. The PCV isnt in the manifold, it is housed in a plastic elbow right off the crank case.
    Dan- 2004 PSM 5spd
    "Days get shorter, nights get longer, snow gets deeper, life gets better."
    Registered User tarmacsti's Avatar
    Dec 2007
    South Africa, Jo'burg
    If I may ask... what is the purpose of changing this valve?
    **__The Hawk-Eye Alliance__**
    Member #0135
    Nov 2005
    Central Florida
    Quote Originally Posted by tarmacsti View Post
    to keep oil out of the intake track
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Dec 2007
    How would I know if I have to replace this?
    Member #0135
    Nov 2005
    Central Florida
    its reccomended to change it every 30,000 miles
    on some of my family members cars i use to change it every other time i did an oil change for them.. the subie one is kinda hard to get to
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    ODJ
    ODJ is offline
    Registered User ODJ's Avatar
    Jan 2006
    Tampa, FL
    Quote Originally Posted by PolarisSnT View Post
    My understanding from a previous PCV thread was that 2004 models have a PCV setup that's meant to be non-serviceable. Has anyone done the replacement in an '04? Anyone have a definitive opinion on whether or not this operation needs to be done with an '04 at all?
    Edit: it's this thread here, which has gotten stickied at some point.
    UNSPOILT BY PROGRESS
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Does anyone know if this is the same for an 06 WRX?
    <-------- Taylor Swift.
    99.5 Jetta...I hear they make 90 to the wheels....
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Registered User 05AspenWhite's Avatar
    Dec 2009
    Valdosta, GA
    Don't know if there are any major differences between the 05 or the 06 STi but here is a very helpful link. I spent about an hour looking for this write up and I hope it helps someone. I am changing my PCV valve tomorrow if, and I do pray, a local auto parts store has one. I don't have a Subaru Dealer near me for miles. Anyways, people will say that changing the PCV valve is non-essential according to the manufacturer, but they are likely basing there calculations on a car that is bone stock. Any Joe Schmoe knows that when you add aftermarket parts to your car, it changes a lot of things, and that's to include the risk of clogging the PCV valve and overpressurizing the crankcase. I think I have said enough.
    How To: Replacing pcv valve - IWSTI.com: Subaru WRX STI Forums
    Dec 2009
    Valdosta, GA
    I will second what rr1911 said in that replacing the PCV valve keeps oil out of the intake track. In extreme cases, a clogged PCV valve can cause oil to push past the piston rings into the combustion chamber and that is not fun for anyone. I guess some signs are oil sodden spark plugs, misfiring, or CEL with blinking cruise control light (caused by misfiring). You just really have to pay close attention when performing maintenance on your car.
    Dec 2009
    Bolton
    Please point me in the right direction to buy one of these i cant find one anywhere?
    Oct 2005
    Late Devonian
    Quote Originally Posted by daja1975 View Post
    Are you in the UK or US?
