Results 1 to 5 of 5
This is a discussion on VF39 or TD04? within the Engine Performance forums, part of the Tutorials & DIY category; I have a issue with my stock trubo. I believe it is going out. Its at the shop as i ...
    Registered User AVOWRXWagon's Avatar
    Dec 2006
    Oregon
    Question VF39 or TD04?
    I have a issue with my stock trubo. I believe it is going out. Its at the shop as i am typing and they have a VF39 there but not a TDO4 like i was going to replace it with. Is it worth the extra money to go with the STI Turbo over the stock. It needs to be replaced any way. I know i well also need new injectors and a reflash on the ecu. I have not had my car for a week and i really miss it! So again is the STI turbo worth the extra money? I do have a up pipe downpipe AVO shortram intake and avo boost controller thus far, it was making 235whp any idea's what it well make with the slightly bigger turbo? Any feedback is appreciated. Thanks!
    Registered User Robert46123's Avatar
    Jul 2006
    Quote Originally Posted by AVOWRXWagon View Post
    If you're going to go with the VF-39 or TD-04 don't go new with either one just because they have it on hand. I'd get a used one as there are plenty of both available because people are upgrading their WRXs and STIs. You can get a really clean example of both easily with the TD-04 going for under $200 and the VF-39 going for under $400. A little patience will pay off big time if your alternative is buying new from your mechanic.
    You don't have a signature that shows your current year of WRX, but if you have an '06 the VF-39 is an easy upgrade because the fuel system is good to go with it. An '02 to '05 will require fuel pump and injector upgrades as well. The VF-39 is a great cheap upgrade for the '06 and well worth the effort.
    2006 WRX WRB Wagon
    Stage 2 Cobb catless DP and Borla Hush CBE
    *Total Loss*
    Dec 2006
    Oregon
    Thumbs up Thanks
    Its not a new one and it would be cheaper than 400, i have found a couple TDO4's for 200 which i think is a little high. My car is a 2002 with 77,000 miles on it. I know i had to go with bigger injecter's but a fuel pump too? More money, that sucks. Thank you for the comments though. The STI Turbo well fit my up pipe and down pipe right? And is the stock Intercooler enough for now till March? I live in Oregon so the weather well not be that warm. Thanks again!
    Registered User bkotzman00's Avatar
    Apr 2006
    York, PA
    the stock intercooler will be alright, you just will not get the full potential until you upgrade the intercooler
    04 WRX Java Black
    Mustang Dyno 218 awhp 216 awtq
    1978 Honda CB400Tll
    yea you know its modified
    1974 Honda CB750 Bobber
    still in the works
    Jul 2005
    With a safe tune and stock boost my friend has ran a VF-39 on his 03 Bugeye for over a year with his stock injectors and fuel pump. Not recommended but can be done if on a budget and thats what was available.
