Results 1 to 7 of 7
This is a discussion on cruise control problem within the Engine Performance forums, part of the Tutorials & DIY category; perrin o2 simulator is this good or not and how install usdm 04 sti cel and cruise control blink cruise ...
    Nov 2006
    usdm 04 sti
    cruise control not working after perrin downpipe
    max rpm. like fuel cut
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    It does sound like your 02 sensor may be screwed up. Also, with a new DP and no cats on an 04 STi, you may be getting fuel cut. Do you have a cat back exhaust on too?
    The perrin simulator works, but I can't say for sure it is the cause of your CEL and blinking cruise light. Do you have a way to "pull" the CEL so you read the code and post it here?
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Nov 2006
    Quote Originally Posted by YBNormal07 View Post
    i have a cat back too.
    how install o2 sensor
    Jul 2003
    PA
    Before you do this, you need to read the CEL to find out what is wrong.
    If it is fuel cut, you will need to port the wastegate, install a DP with a high flow catalytic converter, or put your stock catback back on. This will eliminate the boost creep and fuel cut.
    If it is the 02 sensor, just replacing it would be better than the Perrin 02 simulator.
    Do you have any engine management? Cobb AP? UTEC? Ecutek?
    With the DP and Catback, you really should have engine managment in order to properly control your air to fuel rations. The engine is very likely running extremely rich right now, and that could be source of your problems.
    So..first...find out what the CEL code is and post it up here.
    Nov 2005
    Central Florida
    you can extend the wires on the o2 sensor and put the sensor behind the cat and this should solve ur problem
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Aug 2004
    Costa Rica
    enkei where do you come from?
    my 04 sti have a same problem
    Nov 2006
    Quote Originally Posted by macholeee View Post
    i come from finland
    there is not us sti subaru parts because its complicated and prices is very expensiv.
