Results 1 to 15 of 17
This is a discussion on TGV MOD REQUEST/ Porting along with it within the Engine Performance forums, part of the Tutorials & DIY category; Hey just wondering if someone can post this DIY mod i know the porting is different but usualy they go ...
    Registered User brandonbeeb's Avatar
    Mar 2005
    Toronto Canada
    Hey just wondering if someone can post this DIY mod i know the porting is different but usualy they go hand in hand. Yes ive searched but cant find anything worth while. thanks
    TheJ original quote
    I didn't just fall off the truck from riceville. I mean how do you know the earth is round? You have a book that "SAYS" so... That doesn't mean too much.
    Mar 2002
    Calmer than you are
    there's a bit of a write-up on scoobymods.
    its a pain in the ass job. I did it with help from the local subie guys.
    I just got the APS TGV deletes because they eliminate the bar that runs through the housing and comes with a mechanical CEL fix you can't get anywhere else. (as far as I'm concerened, if you can't get rid of that bar, its not worth doing).
    go f*** yourself
    Mar 2005
    Toronto Canada
    i heard it was still worth it even with the bar. i saw the thread on scooby mods but its to hard to follow without pics and such. I'm going to have my car apart next week doing injectors so i heard this is a good time to do it. also i may port and polish some things what objects are best to port if im doing the injectors?>
    TheJ original quote
    Mar 2002
    Calmer than you are
    Quote Originally Posted by brandonbeeb
    yeah, that's the best time to do it because you pull the TGV housings out and THEN pull the GBOD's off and replace the injectors, but its still WAY more of a job than just doing the injectors.
    Its a crappy install....that's all there is to it. you have to disconnect pretty much every hose and tube running over the motor...and then then put them back the right way
    go f*** yourself
    Mar 2005
    Toronto Canada
    what is a GBOD. kinda new to this all. is it possible to change the fuel rail lines to braided ones like some of the aftermarket kits come with. cleans things up and would hold better pressure. while i have all this apart is there anything i should port and polish?
    TheJ original quote
    Mar 2002
    Calmer than you are
    green brackets of death...they're these green brackets that cover the fuel injectors and fuel rails.
    You don't need new fuel rails...its a waste of money. the problem is not the fuel rails, but the heads...they just flow different rates in different cylinders. you're better off getting Ultimate Racing's cylinder-matched injectors. they're flow-matched for each cylinder rather than to eachother to even out flow rates and EGT's. MUCH cheaper and less work than new fuel rails.
    The GBOD's are the worst part of the injector install....getting them off is a HUGE pain in the ass. If you're doing TGV deletes, you can pull the TGV housing out (the injectors and BGOD's are on the TGV housing) and THEN remove/reinstall making that part of the job easier...but overall its much more work. When you re-install, only put back the GBOD bolts that are easy to get to...there's still plenty of bolts to hold it in place. Some people don't put them back...but they're there to keep the fuel rail from leaking durring accidents and starting fires...I like them.
    there's a howto for the injector install in the tutorial section...check it out. it has some good pictures.
    another mod you can do while you're in there is the throtttlebody coolant bypass. if you don't live somewhere cold, this will lower your charg air temp a bit. there's a coolant line that runs through the throttlebody...its supposed to warm it up on cold days to keep it from freezing. if you live somewhere where that's not a concern, you can bypass the throttlebody (just connect the in and out coolant lines together), and this will keep coolant (which is normally warmer than your air charge) from warming up your incoming air...like I said, don't do it if you live in Maine, or Canada. There's a writeup on scoobymods for this too.
    go f*** yourself
    Mar 2005
    Toronto Canada
    guess the coolant mod is out i live in canada lol. i have UR injectors 725cc's i think they are, there on the way should be here today or tomororow, is anything worth porting at that stage when im doing the injectors?
    TheJ original quote
    Mar 2002
    Calmer than you are
    sounds like you already got the cylinder-matched injectors, so I definately would NOT change fuel rails...those injectors are matched for the stock fuel rail.
    anything else worth porting...the throttlebody (if you're doing the TGV's).
    go f*** yourself
    Mar 2005
    Toronto Canada
    what do i need to do the port. i have a dremel im assuming just a certain bit. is there a write up on this floating around/?
    TheJ original quote
    Mar 2002
    Calmer than you are
    yeah, you pretty much go to town with teh dremel. Scoobymods will have it if there is one. don't take off too much and make sure you keep it smooth to reduce air turbulence.
    make sure you get it VERY VERY clean afterwards because metal shavings + intake = bad.
    you may want to consider buying a "spare" set on ebay or something, and working THAT set instead, and then just swapping and selling yours afterwards.
    I may have a spare set of OEM TGV housings...I'll know as soon as I sell my WRX.
    go f*** yourself
    Mar 2005
    Toronto Canada
    aight thanks alot blarg, youve been incredibly helpful. keep up the diy's im a fan of them
    TheJ original quote
    Mar 2002
    Calmer than you are
    unfortunately, I'm divesting myself of the WRX.
    5 years and 100k miles later, its time for a change.
    go f*** yourself
    Mar 2005
    Toronto Canada
    get an sti then
    TheJ original quote
    Registered User Fahren's Avatar
    Nov 2005
    Garden Grove, CA
    blarg has a new boyfriend.
    SoCal F4 #22 Shoes
    Quote Originally Posted by Forester 2.5 XTi View Post
    If aesthetics was 1st, I wouldn't have bought a Forester!
    Mar 2002
    Calmer than you are
    Quote Originally Posted by Fahren
    jealous?
    go f*** yourself
