Results 1 to 15 of 21
This is a discussion on DIY: STi TMIC with Y-pipe on WRX within the Engine Performance forums, part of the Tutorials & DIY category; Follow this instruction if your USDM STI TMIC came with a y-pipe. Problem: You will notice that Y-pipe to turbo ...
    Registered User WRXreX's Avatar
    Mar 2002
    NY
    Problem:
    You will notice that Y-pipe to turbo hose is about 1" short!
    Solution:
    Order 2" 90 degrees ID hose here for $38 shipped. You will have to cut about 1 cm to create a perfect fit.
    http://www.stylinmotors.com/90Elbow.html
    Problem:
    Brackets will not align with the intercooler on passenger's side. It is perfectly normal for USDM TMIC to not correctly align with brackets. Why? because throttle body hose is about 0.5inch short.
    Solution:
    Intercooler to TB hose is about 67mm ID (too short @ 2" in length). You can order a 2.75" ID turbo hose (3" in length) from here if you decide to correctly mount both brackets. http://www.stylinmotors.com/turbohose.html
    Problem:
    WRX splitter and seal won't align correctly!
    Solution:
    order air splitter and seal kit from rally spec
    RST-9085kit Air Splitter & Seal Kit MY02-03 $84
    http://www.rallispec.com/
    Installed pictures:
    Sep 2006
    Thanks!
    Followed your instructions and they worked flawlessly.
    Stuff from StylinMotors was excellent too.
    Jan 2006
    what modification would be needed to install on a 04-05 for the splitter and seal?
    I am guessing just a 04-05 sti seal and splitter?
    Mar 2002
    NY
    Quote Originally Posted by nvsn8
    I believe so. On my 02 WRX, I had to use JDM splitter and shroud.
    Registered User 06WhiteWRX's Avatar
    Feb 2006
    gaithersburg, MD
    i have an 06 wrx and i got an sti top mount sitting in my garage. which one should i get so that it will reach the hose to the turbo.like u said.. its 1inch short.
    but theres alot off diff sizes to chose from. any specific one i should get?
    thanx
    mods
    Hawk-Eye alliance #111
    Registered User carnitas's Avatar
    Sep 2006
    So Cali
    i also have an 06, do you think its necessary to buy a new splitter?
    Sep 2006
    Quote Originally Posted by LarsBars View Post
    Thanks!
    Wanted to pass on this info, this thread helped me so figured I would submit something of merit.
    sylinmotors added a subie page. They now have inlet hose and a hose kit. I am going to order the inlet hose. let you know how it works.
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    With 06+ you need only the elbow. The throttle body is 1/2" longer due to throttle by wire instead of throttle cable. It has the same TB as the STI now.
    Registered User StarScream's Avatar
    Nov 2005
    5 minutes from the GWB
    just to be sure....The elbow = 2" 90 degrees ID hose ? ?
    Oops....nevermind. The answer to my own question is YES.
    Sep 2006
    Quote Originally Posted by StarScream View Post
    U are correct.
    Sylin' even took the guessing out of the equation. They have a kit for this too now. USDM STI conversion kit
    Jun 2006
    Nor Cal
    U are correct.
    Yeah but with an 06+ you don't need the 2.75 coupler.
    Sep 2006
    Quote Originally Posted by 06wrx4me View Post
    Isn't that what the kit they have comes with? I thought it was.
    Jun 2006
    Nor Cal
    The kit comes with 1-2" 90 degelbow and 1-straight piece and clamps.
    For 06+ WRX you only need the 1-2" 90deg elbow.
    Registered User redrexmeister's Avatar
    Apr 2006
    Sep 2006
    Quote Originally Posted by redrexmeister View Post
    You get what you pay for. Found out the hard way. My bulged and popped in less than six months.
