thank you!
This is a discussion on DIY: VF34 turbo on WRX (with pictures!) within the Engine Performance forums, part of the Tutorials & DIY category; you need to use pill from TD04......
02 WRX - Tuned by Junior 301whp
Visit my install pages:
DIY: STi TMIC install on WRX with WRX Samco IC hose DIY: STi TMIC install on WRX
DIY: Pink injector install DIY: VF34 turbo install DIY: Front lip for $8 DIY: JDM blinker DIY: make your own catch can for <$25!
thank you!
-Dan-
Bugeye Mafia #158
Can you make this a sticky please. Thank you!![]()
Chuck Norris' tears cure cancer. Too bad he has never cried.
nice post, I saved to my bookmark![]()
Not sure how I missed this great thread. Stickey worthy...and so it will be!
tEh PriUs=teH faSTah!@@!
306 AWHP/341 AWT, Stage 2
This is an Good thread![]()
Tomorrow isn't a guarantee.
followed this step by step to do my turbo upgrade!
-Dan-
Bugeye Mafia #158
I am an idiot.
Spammer go bye-bye.
--Ray
Proud owner of a N.E.R.D.
I was looking through the maps on my recently purchased AccessPORT (02 WRX) and I noticed that for the VF34 turbo map it doesn't mention any need of: larger fuel injectors, larger intercooler, or better fuel pump. What would you recommend as needed for the turbo swap? Does the coolant system need to be beefed up as well? Thanks!
For an 02 WRX you most certainly do need larger injectors to use the Cobb VF34 map. It calls specifically for the STi pink injectors.
The Cobb map calls for VF34, STi pinks, uppipe, and TBE.
--Ray
You do not need bigger fuel pump and TMIC according to Cobb Tuning.
You would definitely need JDM STi pinks, TBE, and uppipe.
Hey, how do you reach the squeeze clip on the oil return line once you've set the turbo on? Someone told me to use a longer piece of hose, but what kind will be able to withstand the heat? I have heater hose or power steering hose to choose from. Anybody? Bueller?
'03 WRX Wagon
Sedona Red Pearl
you may want to start a new thread to get replies faster.
2005 WRB WRX "was" STAGE 2
Thanks for the writeup and pics. Something that might help: I used a curved hemostat to hold the squeeze clamp fully open on the oil return line. (Its a locking clamp-like they use in surgery) Then set the turbo in place and just slid it up and unlocked it. I really appreciate the tutorial, it made it possible for me to do it myself. So far, no leaks. Thanks a million.
PS, a 3/8 x 3" socket extension plugs the coolant hose perfectly
'03 WRX Wagon
Sedona Red Pearl
