Remove a battery
Move a windshield washer reservior (two bolts)
Bracket is visible now!
You will have to take this cover off in order to reach a bolt.
Removed!
You can reach from the top to unbolt this hard to reach 10 mm bolt
Here is driver's side GBOD. You will have to bend a AC line a little and wiggle it around to get it out. It took me about 30 minutes to remove IC and GBOD.
Comparison:
You will have to bend a fuel line slightly in order to remove stock injectors. Be sure to use a gas to lubricate o-rings before installing pink injectors.
Here are two stock injectors:
There are two 12mm bolts holding a fuel rail
Remove this 12mm bolt that's holding a fuel rail
Injectors removed:
Pink installed:
LinkBack URL
About LinkBacks
