DYI: Pink injectors on 02-03 WRX - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
This is a discussion on DYI: Pink injectors on 02-03 WRX within the Engine Performance forums, part of the Tutorials & DIY category; Originally Posted by articulate81 What is the name of the cover you removed to reach the 10mm bolt. I need ...
  1. #31
    Registered User 2:43AM's Avatar
    Sep 2008
    NWI
    Quote Originally Posted by articulate81 View Post
    What is the name of the cover you removed to reach the 10mm bolt. I need a replacement and dont know the name. Thanks!
    Are you talking about the cover in the first pic? Good question.
    My Subie shop manual fails to reconnect the hose attached to it. I imagine it is along the lines of "drivers side crankcase blowby gas cover."
    What the hell did you do to it?!?
    Quote Originally Posted by WRXreX View Post
    Removed!
    You can reach from the top to unbolt this hard to reach 10 mm bolt
  3. #32
    Feb 2010
    Chicago
    'click'
    So I'm having a really hard time getting the injectors to 'click' back in to the fuel rail. Do I just have to push/pull/force the injectors back in harder, or is there some trick?
  4. #33
    Sep 2008
    NWI
    Quote Originally Posted by tegulizard13 View Post
    There will be a slight click. Nothing noteworthy. If the o-rings are properly greased, you may not feel anything. In fact, they may not even stay in the rail. I inserted the injectors into the engine first, then carefully aligned and pressed down the fuel rail onto the injectors. They went in real easy.
    Just be sure before starting the engine that you check for leaks. Prime the fuel pump by turning the key to 'ON' and check for drips, smells and/or wet spots with a good flashlight.
