2016 WRX high pitched noise, vibrating 4th gear
Results 1 to 15 of 21
This is a discussion on 2016 WRX high pitched noise, vibrating 4th gear within the Engine Performance forums, part of the Tutorials & DIY category; Hey everyone, Ive got a couple weird things going on with my 2016 WRX with just about 4,000 miles on ...
    Registered User JediMikeTrick's Avatar
    Apr 2015
    Hey everyone, Ive got a couple weird things going on with my 2016 WRX with just about 4,000 miles on it.
    The first thing is a high pitched noise coming from the engine bay during slow RPM deceleration. It sounds almost like old brakes squealing but I know it is not that due to being able to recreate the sound parked at idol. I have captured the sound in a video and attached it below. Let me know what you guys think.
    The second thing is that my shift knob vibrates pretty heavily when I am in 4th gear. This happens only if I am accelerating. The shifter can naturally move a bit backward and forwards while in gear, so when i accelerate it naturally goes backwards as far as possible and is vibrating, almost like its resting on something that it shouldn't be. If i gently move the shifter forward, in that pocket it has in gear, it instantly stops vibrating. This could be due to the fact that my shift knob is a bit too heavy, its 1.4 pounds. So the force of the car plus gravity of the heavier knob could be pulling the shifter back too far, I will be testing my stock knob later tonight. This also does not happen in any other gear.
    Thanks everyone, let me know if any of this sounds odd.
    Apr 2015
    Bump for educated answers
    Registered User 15WRBlue's Avatar
    Dec 2014
    Near Lansing MI
    Sorry, but not a clue. I'd just take it in to Subaru... it is a '16 under warranty unless you have mod'd the engine?
    Ryan
    '15 WRX Premium -- Sunroof, short throw, upgraded lights (SubiSpeed LED DRL boomerang, OLM HID 5000K low-beams, OSRAM 5000K high-beams), TapTurn, STi Wing, 20% Tint
    Other current: '92 Stealth RT/TT, '07 Avalanche LTZ
    Previous: '04 Saab 9-3, '02 WRX, '94 3000GT SL, '91 Eclipse GSX, '82 Porsche 931 (924 turbo), '79 Saab 900T, '81 Mitsubishi Starion, '80 Triumph Spitfire, '74 Saab Sonett III, '72 Opel GT
    Apr 2015
    Ive got an intake and a tune so im not in the best spot. But the issues I am having could be unrelated
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    When did the sound start? Day 1? Or after the tune? No other mods "at all" ??
    Apr 2015
    I have no other mods at all. And I most likely started hearing it after getting the Accessport. I dont drive around like a crazy person though. It sounds like something just needs to be greased or something.
    Jul 2015
    Check your belt tension.
    AFA the 4th gear thing, They will most likely blame anything transmission related on the "power" modifications.
    I'd go back to stock since your mods are so light, and take it in. I remembered this thread yesterday and on the way home I noticed a very slight vibration in 4th if I pull back on the shifter, but nothing normally, and I have to pull it back with more than a couple pounds of force to feel anything.
    Apr 2015
    Yeah I will be taking it in at some point. I was hoping for an easy fix or people telling me that they experience the same thing and that its normal.
    Jul 2012
    I have the EXACT same issue with my 2016 WRX in 4th gear...exactly how you described it. I haven't taken it in yet because I fear what the dealer with screw up on my car (like usual).
    Aug 2012
    Tucson, AZ
    If you have warranty.....use it
    Sent from my SCH-I545 using Tapatalk
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Aug 2015
    I too feel the same thing on my 2016 wrx on 4th gear. And I just hit 1,000 miles. Maybe it's a normal thing? I'm not sure. I just kinda move the knob up to where it stops vibrating and leave it there. But it is pretty annoying none the less
    Jul 2015
    Seattle
    I've got 3600 on my 16 and the vibration has been present in forth since it came to me at 7 miles. I've been less than concerned as it only happens then, all other gears are free of noise and vibration. I track the car and run mostly in 3rd and 4th to red line and I will worry about it when the warranty runs out. Drive it, stay in 3rd or 5th if it bugs you, turn the tunes up enjoy it or beef it to the dealer if you can't live with it. Life's to short....let the clutch out and cruise. best of luck
    Jul 2012
    I drove another 2016 WRX and it actually did the same thing. I pulled off my shifter boot to take a peak and I couldn't see anything touching or rubbing (like a shifter plate) that would cause it.
    Dec 2015
    Ive been noticing the same thing with my 2016 sti, i dont know when it started but i only have 1000 miles on it, and only mod ive done is a intake. afraid to use my new accessport.
    Registered User Goose42's Avatar
    Jun 2014
    PNW
    Quote Originally Posted by Hintze89 View Post
    So you are running an intake with no tune?
    Or he is rolling down the street in his new slammed ride vaping out the window, enjoying the tow truck ride. - XJman
    2017 ISM Impreza 5MT Hatchback Sport
    2015 WRX COBB Surgeline Stage 2 Pro Tune (Sold)
    Journal-
    http://www.clubwrx.net/forums/builds...ml#post3579257
