DIY Chipping
Page 1 of 3 123 LastLast
Results 1 to 15 of 37
This is a discussion on DIY Chipping within the Engine Performance forums, part of the Tutorials & DIY category; I am looking to install a chip myself to improve gas mileage & torque a bit for my 2013 wrx. ...
    Registered User SimPar's Avatar
    Apr 2014
    Levis, Quebec, Canada
    DIY Chipping
    I am looking to install a chip myself to improve gas mileage & torque a bit for my 2013 wrx. Something cheap though, does this thing below would work or somebody has something better to propose? Thanks again
    Performance Turbo Boost Volt Engine Power Chip Stabilizer for Subaru | eBay
    May 2007
    orlando flawduh
    do NOT buy that.
    if you want to improve power/torque/etc you need a proper tune, whether it be via an accessport or an opensource tune.
    "cheap" and subaru do not play well together.
    desiree
    Jan 2012
    New Jersey
    Save your money get a custom tune, an access port, or tactrix cable then E-Tune
    tss tss did someone say Chip???
    CFLip2x 2012 WRB WRX Build
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    :facepalm:
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    2007 Outback 3.0R wagon
    Contributes Nothing ShiftingLanes's Avatar
    May 2013
    Riverdale, NJ
    http://shiftinglanes.com
    '14 DGM WRX Limited Hatch
    I'm a build thread?
    Stink-eye Mob #49
            MainFrame's Avatar
    Austin, TX
    Sep 2005
    Sorry, these are not VWs... there's no such thing as "chipping" a subie...
    What you want is an opensource or cobb off the shelf tune (OTS).
    If you want better mileage, get your MAF properly scaled in closed and open loop, then remove your roof rack, keep your windows up, and use cruise control.
    I can get 28MPG highway on my 2011 wrx with a slightly modified cobb stage 1 map (smoothed out some timing cells), all stock intake/exhaust, with cruise control set at 2600rpm in 5th gear.
    -- Dave
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by AcquaCow View Post
    ..and use cruise control.
    For what it's worth, I get better fuel economy not using cruise control.
    Apr 2014
    @cflip2x, can you point me to instructions And hardware needed so I can learn about this more?
    Thanks everyone for not letting me buy those phony eBay chips!
    Oct 2010
    Portland, OR
    Registered User RichD514's Avatar
    Jun 2012
    Long Island, New York, United States
    background: When a racer or street racer wants to improve their vehicles performance in a race, they generally shut off all electronic components in their vehicle including headlights, radio, fans etc. This is done to maximize all the available voltage that is essential for engine components and the drivetrain.
    Problem: A vehicles alternator produces varying voltage at different RPMs, while at the same time is under pressure to give proper voltage to other devices such as radio's, headlights, electronics in the vehicle. These electronics can produce noise in the system and cause voltage drops that can hurt performance. Your spark plugs use high voltage to ignite gas in the engine block, without proper voltage delivery to these spark plugs a loss of horsepower is imminent.
    Solution: The RAIZIN Voltage Stabilizer. Maintains consistent voltage and improves both your electrical system and engine load. Using high tech capacitors and voltage regulating circuit, this device makes sure your vehicles voltage remains stable when voltage drops, noise and fluctuations occur becomes of engine RPM and running accessories such as radio, headlights, climate control etc..
    Sweet! Now you can street race with your sterio bumpin!
    Apr 2014
    Thanks everyone. Found a tuner in my area, gonna go with boost controller.
    Oct 2010
    Portland, OR
    Quote Originally Posted by SimPar View Post
    What? No!!!!! You still aren't getting it! Your boost is fine, it's the engine management you want to tune. I'm assuming here you're getting a manual boost controller, which essentially eliminates the the factory boost control system. Read here: WTF Tuning Part 2: The Turbocharger 101 & Basic Boost Control
            MainFrame's Avatar
    Austin, TX
    No need for a different boost controller.
