DIY Chipping - Page 2
Results 16 to 30 of 37
This is a discussion on DIY Chipping within the Engine Performance forums, part of the Tutorials & DIY category; I hope the car is ok Sent from my SCH-I545 using Tapatalk...
    Aug 2012
    Tucson, AZ
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Registered User SimPar's Avatar
    Apr 2014
    Levis, Quebec, Canada
    Got the cobb accessport port v3 with Intake. Now that I flashed the map, do I need to load the map each time I start the car? Do I keep it connected at all time? How can I use as a digital turbo psi gauge? Thanks
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Did you read the manual at all?
    2007 Outback 3.0R wagon
  6. #19
    Apr 2014
    Don't have it hence my questions.
  7. #20
    Oct 2011
    Santa Ana, CA
  8. #21
    Apr 2014
    Thank to you for that, manage to answer my first two questions. Still not sure for the last one
  9. #22
    Sep 2005
    I have my own questions for you.
    1) what car/year
    2) what intake do you have
    3) what map did you flash and how did you flash it?
    Now for your questions:
    - Do I need to load the map each time I start the car?
    Nope, once a basemap is flashed, it's there till you change it. If you flash a realtime map, it'll be present in memory until you disconnect the car's battery.
    - Do I keep it connected at all time?
    You can with an apv3, the old v2s never shut off the display and would get screen burn. The V3 will shut itself off a few mins after you turn the car off, or if you hit the power button.
    - How can I use as a digital turbo psi gauge?
    Go to the Monitor or Gauges section and you can pick which data points you have displayed (You can display up to 6 simultaneously on the v3).
    Use the up/down buttons to pick the location you want the gauge to be at and hit the center button to select/change that gauge
  10. #23
    Apr 2014
    DIY Chipping
    I have a 2013 WRX with k&n typhoon intake. Had it pro-tunes based on Cobb map right on the access port. Flashed it on the device itself too, everything installed without any errors or check engine afterwards. Test drive not done yet. Thank you for everything
  11. #24
    Administrator ...De Rerum Natura TheJ's Avatar
    Bro do you even live in the Dirty South
    SimPar make no mistake, asking here was the smart thing to do.
    -The J 𒂼𒄄
    "Driving most supercars is like trying to manhandle a cow up a back staircase. . . This is like smearing honey into Keira Knightly" -JC
  12. #25
    Sep 2005
    Quote Originally Posted by SimPar View Post
    So you had the car pro-tuned with the K&N Typhoon installed then?
    You have the AP married to your ECU then, and I'm assuming flashed the map from the accessport to the ECU (likely done during the tune anyways).
    Did your tuner copy your MAF table into the economy and other built-in maps as well?
    -- Dave
  13. #26
    Apr 2014
    Yes i did Back it up And économy mode is there too.
  14. #27
    Apr 2014
    Actually made I typo I have the v2 accesport but I'm still unable to have it display the boost readings in psi. All I can see is minus numbers going up and down in a unit I've never seen before?
  15. #28
    Oct 2010
    Portland, OR
    Did you look at the boost gauge with the car idling? If so, the gauge is simply reading manifold vacuum. You will never show boost or zero gauge pressure at idle. Since you're in Canada, I would imagine the AP is set to Metric units, in which case boost would typically read in Bar, and vacuum in mmHg.
  16. #29
    Apr 2014
    Exact. Is it possible to change the type of units displayed then? Thanks again
  17. #30
            MainFrame's Avatar
    Austin, TX
    Yes, it's in the settings.
