No, but I'm still curious how you got the STI intercooler on there. Pics?
This is a discussion on Electric exhaust cutouts? within the Engine Performance forums, part of the Tutorials & DIY category; So back to my original question, do you happen to know of a reliable brand?...
2012 DGM 5 DOOR WRX
Mods: Stage 2+
"I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
Official ClubWRX Creeper
Thanks, and I post pics when I'm off work.
Let me google that for you.
User Mainframe has one if I recall...but he had a stock CBE on after the downpipe, so he had a reason to have one. Seems like a waste of money OP, but to each his own.
Is the downpipe catted? I would advise against getting one installed right in the downpipe. That could potentially impact your tune, although I'm not dead certain of that. If you want the noise + real performance, just get an external wastegate setup. That will provide a significant performance gain (once properly tuned), and is essentially a boost-controlled exhaust cutout right near the downpipe anyway.
TL;DR: All the noise + no tune issues (once it itself is tuned for) + real performance gains = External Wastegate setup
Isaac -- 2003 WRX sedan Stg II
He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
Thanks for the idea, but is it always loud? Liked the idea of cutouts because of the option to make it quiet when ever.
What's the price like on getting something like that done?
Facebook me here
Originally Posted by Mikie13
Cool, thanks.
If you want a good cut out, get a badlanz cutout. 5 year no questions asked warranty and very good quality craftsmanship on them.
in for pics
If the cutout is installed pre-catalyst, you might see minor gains. This is more useful when you get into heavily modified car (if you're not bypassing a cat, it will essentially be a noise-maker at your level); until you get into GT30R+ sized turbos, I wouldn't bother (a better mod would be an EWG, instead).
Where do you live? The issues people have is in locations that use rock salt; rock salt causes the motor to seize up, and then you're stuck with whatever config it's in when it happens.
QTP makes a good electronicaly opperated cutout. But there are two things to keep in mind when considering one. First, every one I have seen in use has dealt with repeated electric motor failures. They just don't last that long, and it's expensive to replace the motor. The second issue is that every butterfly vlave type cutout I have seen or heard of leaked when closed. So you're always going to be dealing with an exhaust leak.. not a huge deal, but it sounds bad, and could potentially cause you to fail saftey inspection.
Those two prevelant issues, along with the fact that the QTP cutouts cost like $180+ steered me away from them completely. Instead I installed a manual 3" cutout that I purchased from Summit Racing for $30 and paid $20 to have welded in. It never leaks, cannot fail, and it only takes me about 20 seconds to remove the block off plate (held by three large wing nuts), and maybe a minute to reinstall. I can sit down next to the passanger door and easily reach it where ever I am.
For what it's worth, I only open mine for about 30 minutes once every six months.. it is obnoxiously loud.
So what kind of gains can be seen with ewg?
