how do i do a boost/vacuum leak test?
Results 1 to 3 of 3
This is a discussion on how do i do a boost/vacuum leak test? within the Engine Performance forums, part of the Tutorials & DIY category; i have a 02 wrx wagon, and i have a pretty bad idle surge i couldnt find much in to ...
    May 2012
    i have a 02 wrx wagon, and i have a pretty bad idle surge i couldnt find much in to forums on how to do it. if you have any suggestions that would be awesome
    Oct 2011
    Santa Ana, CA
    You need a tool called a "boost leak tester". You will pump air into your intake track and listen for leaks or spray soapy water to get a visual of the leak.
    A quick Google search will yield many sites to buy one premade and instructions to make one yourself if that's your fancy.
    But until then, get a screwdriver and tighten every hose clamp from the air-box to the throttle body. Dont torque the crap out of it, just a sure hand tight.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Here's a good link to a DIY one. A bit on the fancy side, but you can scale it to your needs:
    Another DIY Boost Leak Tester - Home Depot and AZ parts - NASIOC
    2007 Outback 3.0R wagon
