boost install help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
This is a discussion on boost install help within the Engine Performance forums, part of the Tutorials & DIY category; Yeah went for shock value and controversy on that one....
    Palmyra, NJ
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    When I installed my Defi gauge, I taped a small magnet to the end of the wiring (tube in your case), fished it down, and then used an extendable pointer I have with a magnet on the end to capture the wiring magnet and pull it through.
    It sounds like it was much easier on the older cars though. I just used the grommet right behind the brake pedal, and easy to access from inside the car.
    2007 Outback 3.0R wagon
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Quote Originally Posted by Drews View Post
    You seem to fail at installing things...maybe you should leave it to the pros.
    Man, I'm glad you're not around to "encourage" me while I build my buggy.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
  6. #19
    Registered User wrx1234's Avatar
    Sep 2009
    Dover DE
    If it's taking you more than 30 mins you need to get someone to help you. There was absolutely no need to take off the IC. Like drews said there are several holes in the firewall it seems like you picked the worst one. Under your steering wheel to the left there is a rubber plug with several wires through it, that hole goes to the fender. Pop a few of the plastic fender screws out and push the cable up in to the hood. 10-20 mins tops...
  7. #20
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    There are 2 ways of going about this.Both are not easy.It took me a while to fish the wire through the firewall.I heard from others that it was incredibly difficult too.
    The way I went about it.I used the grommet in the following pic.I ran a steel wire into the cabin first.It comes out in about the center of the console & you should be able to catch it after some cursing & trying near the gas pedal,or it may decide to go to the passenger side(like it did for me),in which case you catch it & route it to the driver side.
    Second method which is what I used to run my audio wiring involves running the wire through your driver side fender through a grommet situated behind the plastic piece which has the WRX engraved on it.This naturally involves partially taking off the fender liner.
    The first method is relatively easier.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
  8. #21
    Aug 2010
    Yonkers/NYC
    Its a pain to get to...use a coat hanger and it will make your life easy.
    I had to tell my GF the same thing.
    T0ny
    2011 WRX
    2012 FXT
