Why not just do a 2.5 hybrid? You'd have an extra 500cc's of bore n' stroke plus it would be more reliable if done right...
This is a discussion on EJ20 Honing - Grit and Hone Diameter within the Engine Performance forums, part of the Tutorials & DIY category; I'm planning to hone my EJ20g block for v5 207 forged pistons and new rings. There are also some light ...
I'm planning to hone my EJ20g block for v5 207 forged pistons and new rings. There are also some light scratches I'd like to see disappear as well, nothing major.
What grit should I use for the initial hone and for a final hone to achieve the proper arithmetic average (Ra) for my rings/pistons? I'm planning to use a flex hone. According to their website, 320 grit gets an Ra of 18-30 and 240 gets 24-32.
Thanks!
If you're not the strongest, be the toughest. If you're not the biggest, be the fastest. If you're not the most loved, be the most feared.
Black Diamond Pearl, JDM Version 5 STi Type RA Limited swapped USDM 1999 2.5RS
Hawk-Eye Alliance #801
Yes... you need engine management for engine modifications
http://www.clubwrx.net/forums/tuning...ne-mods-6.html
buy me one and I will. PLEASE NO MORE 2.5 SWAP SUGGESTIONS!
I don't mean to sound like a *ick but if I wanted to know whether I should get a 2.0 block or a 2.5, I would have made a thread with a poll asking so. I'm more then halfway through my rebuild and theres no turning back or starting over with a 2.5 block.
Durring my engine failure I was considering rebuilding my block, but with all the added cost of rebuilding it and parts it was cheaper to just buy a new shortblock and resell my old one...
