what boost controller and BOV should i run
Results 1 to 4 of 4
This is a discussion on what boost controller and BOV should i run within the Engine Performance forums, part of the Tutorials & DIY category; Hey all, i have a MY02 STi and was wondering what boost controller and BOV i should run on my ...
    Nov 2010
    Post what boost controller and BOV should i run
    Hey all, i have a MY02 STi and was wondering what boost controller and BOV i should run on my car? i need all the advice as i can thanks.
    Remap it instead. Search for a local solution in your area.
    Would Never, Ever Say Something Bad About an Admin's Mom SonicWagon's Avatar
    Jul 2007
    Santa Cruz New Mexico
    In most cases (likely yours) the stock BPV and stock BCS are the best way to go.
    "It is at our most challenging times that we must cheat our very hardest" - Eric Theodore Cartman
    Quote Originally Posted by Weasel 555 View Post
    so whose up for been banned?
    I is teh b1ggest douche evarrrr!~
    Registered User Pylonpounder's Avatar
    Aug 2010
    Factoryville, PA
    I've never heard good things about sticking a manual boost controller on scoobs. As for BOV...don't go there. The stock bypass valve returns air from the turbo into the intake manifold when your shifting, idling, etc. That's good, because that air has been read by the MAF sensor, which tells the engine "Okay, send this amount of fuel." a BOV releases that air directly to the atmosphere, thus making the MAF sensors calculations inaccurate, and causing your engine to run with less than ideal air/fuel mixture.
