Results 1 to 2 of 2
This is a discussion on Mac fault code within the Engine Performance forums, part of the Tutorials & DIY category; I have a 04 wrx, it has no cat converter and a 3" exhaust, engine light came on, a Mac ...
    May 2008
    Mac fault code
    I have a 04 wrx, it has no cat converter and a 3" exhaust, engine light came on, a Mac code reader indicated fault code P0420, "cat efficiency below threshold, bank 1", it has been reset and keeps coming on, I've been told changing the sensor won't help. What next? Is there a "blocker?" or something else that can replace the sensor, so the check engine light stays off and the car performs like it should??
    Search CEL PO420. Example:
    Need help!!!! with a MIL Eliminator
    There are two different solutions presented; I'd go for the cheapest.
    Also search EM or engine management.
