im pretty sure stock boost is 11.6 psi so i mean if you car seems fast then i doubt you are lossin boost. because only running on 5psi will make your car a whole hell of a lot slower. your best bet is to look at the gauge. any leaks? bad connections?
LinkBack URL
About LinkBacks
I figured you were interpreting MPa as PSI.
