Help!!!!!!!!!!!!!!!
Results 1 to 3 of 3
This is a discussion on Help!!!!!!!!!!!!!!! within the Engine Performance forums, part of the Tutorials & DIY category; I have a 03 yellow wrx and I have an intermittent problem that the dealership has told me that it's ...
    Registered User traumawrx's Avatar
    Oct 2007
    Help!!!!!!!!!!!!!!!
    I have a 03 yellow wrx and I have an intermittent problem that the dealership has told me that it's a wrx problem and I should get used to it. Sometimes, especially after I have driven it for a while, distance or in traffic, it stalls and jumps when I push it at all. Not flooring it, even a gentle push. It feels like it's not getting gas or air and it drops in power when I accelerate, like a push...stop...push...stop, almost like your running out of gas. I just had it tuned (plugs n all), I have a blow off valve, cat back, and a short ram.
    Quote Originally Posted by traumawrx View Post
    No. The car runs smoothly when working correctly. You have a fault.
    What do you mean by "tuned?" Do you mean a tune-up (spark plugs, oil and oil filter, air and air filter etc. or do you mean loading a custom map to the ECU?
    Is the CEL on? What error codes is it complaining about?
    I have a blow off valve... and a short ram.
    Fix these problems and see what happens. Replacing both with the correct factory parts certainly won't hurt the car. Also, if you've just had a tune-up, check the MAF sensor connection and make sure the sensor itself is clean. You might also check the entire intake track for leaks (but you already know you have at least one leak -- the BOV).
    Oct 2007
    No, tuned just means the 60,000 mile tune up, no ECU mods. The CEL does not come on, does that mean a minor replacement or adjustment? Would a BOV go bad and leak? By the car doing that action, does that mean a leak in pressure somewhere? Do you have a BOV? advantages vs disadvantages?
