Results 1 to 8 of 8
This is a discussion on Help...new Owner..trouble With Car within the Engine Performance forums, part of the Tutorials & DIY category; I have a 03 yellow wrx and I have an intermittent problem that the dealership has told me that it's ...
    Registered User traumawrx's Avatar
    Oct 2007
    I have a 03 yellow wrx and I have an intermittent problem that the dealership has told me that it's a wrx problem and I should get used to it. Sometimes, especially after I have driven it for a while, distance or in traffic, it stalls and jumps when I push it at all. Not flooring it, even a gentle push. It feels like it's not getting gas or air and it drops in power when I accelerate, like a push...stop...push...stop, almost like your running out of gas. I just had it tuned (plugs n all), I have a blow off valve, cat back, and a short ram.
    Oct 2005
    Ocean Grove, NJ
    ditch the BOV and Intake
    put these items back to stock and the problem will likely go away
    Registered User kiger0183's Avatar
    Oct 2005
    SLC, Ut
    Quote Originally Posted by Micah View Post
    +1
    Stage II and loving it!
    Jun 2007
    Great Salt City of Utah
    +1 I know it sucks but it is probably the reasson for your rough idle. I would start with repalacing BOV and if that doen't remedy the problem then seek out the stock air box.
    Oct 2007
    so a leak in pressure could cause this problem? Is that the most common reason or are there others. How often does the BOV leak, do you use one (advantages vs disadvantages), and is this what happens when it malfunctions? This problem happened before I added the short ram, but now it's just become more frequent. Is this lag in performance damaging my wrx? thanks for your help...
    Nov 2005
    Central Florida
    its the bov subies dont like bov's
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Oct 2004
    Westchester Cnty, NY
    Its not an issue of a pressure leak. You need to put the stock bypass valve back on the car. Your car is running rich from the BOV and thus it is idling poorly. Check out the New Member FAQ.
    2008 Satin White Pearl WRX Sedan w/ Navi
    2005 San Remo Red WRX Sedan w/ VF34 (traded)
    Pi Kappa Alpha | New England Flat 4
    The BOV is not malfunctioning, it is by definition an intake leak and is likely causing the car to stumble as a result. See The Big BOV Thread.
