Results 1 to 1 of 1
This is a discussion on Intake Information for n00bs within the Engine Performance forums, part of the Tutorials & DIY category; Most major Subaru tuners agree that the stock intake is adequate to power levels in the 400HP range. It also ...
    Administrator TheJ's Avatar
    Dirty South
    Post Intake Information for n00bs
    Most major Subaru tuners agree that the stock intake is adequate to power levels in the 400HP range. It also has the following advantages:
    • The standard air scoop is mounted high in the engine bay. This makes it resistant to ingress of water. The design of the fender snorkel helps to remove any water that is drawn in by this scoop.
    • Air drawn in is cool, since the air comes from the edge of the engine bay, and at speed, all air will be drawn from outside.
    • The standard system is quiet since the resonator in the fender helps filter out noise from the air flow.
    • The stock ECU is calibrated to work perfectly with the stock intake system.
    Here's a good link on Intakes from the Unabomber.
