Results 1 to 2 of 2
This is a discussion on stock ecu within the Engine Performance forums, part of the Tutorials & DIY category; how do you take out the stock ECU? i need to get it flashed back to stock before the dealership ...
    Mar 2005
    stock ecu
    how do you take out the stock ECU? i need to get it flashed back to stock before the dealership takes it and my car is not driveable right now, so any suggestions would be great, thanks!
    Registered User btrenhol's Avatar
    Fort Collins, Colorado
    The ECU is under the passange footwell up by the glove box.
    There is I think four bolts holding a kick plate on and two or three holding the ecu in. disconnect the wires from the ECU, they only go in one way so dont worry about making where they go.
    Oh and make sure you disconnect the battery and press the brake a few times before you unplug anything!
    Vishnu has instructions with pics on there site
