up pipe removal without jacking engine up
Results 1 to 15 of 22
This is a discussion on up pipe removal without jacking engine up within the Engine Performance forums, part of the Tutorials & DIY category; is there anyway possible to get the uppipe out without jacking the engine up or losening the manifold? thanks again ...
    Jul 2005
    california
    nate
    Banned JDM 3SGTE's Avatar
    Apr 2003
    you would have to remove or at least completely loosen the turbo. but i think jacking up the engine is the easiest way. you only need about 1-2 inches for the uppipe to slip out. its only one nut that you need to undo.
    Administrator
    May 2003
    Taking a shortcut often makes the job take longer.
    Registered User topend's Avatar
    Nov 2004
    New Britain, CT
    i have to agree that jacking up the engine is best. i tried removing the uppipe without jacking or removing manifold and didnt work, i than resorted to jacking up the engine and it was easy after that.
    New England F4
    Top End Racing
    Registered User IronMedic's Avatar
    Jan 2005
    Puyallup WA
    yeah i decided to take off the nut on both sides to make it easy. you have to pay attention to how the engine comes back down on the mount. if i remember, it needs to line up right. you can tell when you put it back down and you cant get the nut on right. just give the engine a little shove and it will slide in
    2005 Nissan 350z roadster
    Originally Posted by BrianH
    I can hit 10K more posts before a neon R/T will hit 60mph.
    Jan 2005
    Quote Originally Posted by JDM 3SGTE
    Done 4 or 5 cars so far, still haven't had to jack up the engine or loosen the turbo. It's all about twist and roll....twist and roll...
    Jul 2005
    california
    whats the secret then pingflood? did you have to loosen up the turbo bracket. if i am doing it right i might just have to take off the 2 bottom bolts on the uppipe and then the 5 bolts by the turbo and it might come out otherwise i have to jack the motor up right. am i missing any other steps up to the point of the 7 bolts? is there anything else holding it togeather?
    Jan 2005
    Quote Originally Posted by sethtroy
    Well, here's what I did (briefly):
    Remove turbo heatshield(s)
    Remove downpipe (you can loosen it enough to wrestle it off the turbo but it can be some effort, easier to just pull it)
    Unplug EGT sensor
    Remove plastic shield in pass side wheel well to access O2 sensor
    Remove O2 sensor
    Remove passenger manifold heatshield
    Remove passenger side manifold (3 nuts to head, 2 nuts/bolts to intermediate pipe, 2 nuts/bolts to uppipe)
    Remove 5 bolts holding uppipe to turbo/bracket
    Pull uppipe down towards where manifold was, twist around 180 degrees and push back up and over to clear all the crap. It might take a few minutes to figure out but I have yet to see a car this didn't work on. It might help if you pull the EGT sensor probe from the uppipe.
    I may have missed a step or three there, but that's the general idea...
    Administrator
    May 2003
    Quote Originally Posted by pingflood
    Unplug EGT sensor
    Remove O2 sensor
    Adding to that:
    Remove one 14mm nut - less than a minute
    Place jack under oil pan with piece of wood in between, and jack up a few inches - less than a minute
    Uppipe falls out - no wrestling, twisting, or scraping of parts
    I've tried it both ways. Jacking the motor up is the easiest way.
    Registered User VVVV's Avatar
    Sep 2003
    Denverish
    That explains why it took me so long. I jacked up the engine and pulled it out without loosening or removing the manifold at all. I pinched and shorted a transmission sensor by jacking it up too far, so be careful. I was afraid of exhaust leaks if I loosened the manifold at all. This would have made it much easier.
    Administrator
    May 2003
    Quote Originally Posted by VVVV
    Disconnecting the battery is always a good idea on medium to large jobs.
    Registered User talonboost18psi's Avatar
    Jul 2005
    WElls Maine
    so it sounds to me that this job is hard to do and it can be done a few different ways. I want to know if any one else has done it with out removel or losening the manafold?
    Administrator
    May 2003
    Quote Originally Posted by talonboost18psi
    To do it that way, you need to remove the turbo.
    Registered User 5spdfrk's Avatar
    Dec 2003
    Southside o' ATL
    I took mine out w/o loosening the turbo or manifold. Like stated before, it comes out with a twist and roll, and if you pay attention how you got it out, it will go back in the same way.
    '02 WRB WRX
    '92 Civic Si
    Registered User PolarisSnT's Avatar
    Aug 2002
    Staten Island, NY
    Yep the twist and roll...works pretty good. Only thing was that I had to use a hammer to beat it out.
    Dan- 2004 PSM 5spd
    "Days get shorter, nights get longer, snow gets deeper, life gets better."
