Results 1 to 7 of 7
This is a discussion on for those with intercooler waterspray kits within the Engine Performance forums, part of the Tutorials & DIY category; if you mounted a water resevoir in the trunk, can ya tell me how you led the hose to the ...
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    if you mounted a water resevoir in the trunk, can ya tell me how you led the hose to the trunk? i was wholly confused when i tried to do that with mine, and i couldn't find a friggin way, so i just led the hose through the middle seat pass-through
    oh btw, what did u use for the resevoir? post pics!!! (cause right now i'm using an old milk gallon jug )
    Silver 911
    WRX's older brother
    Nov 2001
    alright, c'mon. i know a bunch of u guys on here have IC sprayer kits - lets hear some input!!
    Silver 911
    WRX's older brother
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    I cheated - I have a wagon which already has two spray motors fitted. I rewired the motor to the spray controller and pulled off the rear spray hose and replaced it with the hose that goes to the spray nozzles.
    The rear motor is mounted slightly higher than the front nozzles - so it doesn't run me out of water for the windscreen.
    I rarely used the rear spray - so it was a good compromise for me!
    PNG
    PNG is offline
    Registered User PNG's Avatar
    Oct 2002
    San Diego
    I'm eventually gonna rig a permanent sprayer using the washer fluid tank. Mine's a wagon, too, but I'll keep both pumps functional by adding a third externally to run the sprayer, and putting a bulkhead fitting and dip tube into the top of the tank. That way, it won't leak, and I can put the end of the pickup tube down about where the second pump intake is so that I don't run the front washer system dry.
    Nov 2001
    damn...i'm tryin to figure out how to run the hoses to the trunk, but both of ya'll have wagons lol
    Silver 911
    WRX's older brother
    Jun 2002
    I didn't get full on details - but the MRT tech that I spoke to about this when I was considering a trunk reservoir said you could run it under the carpet through the cab and then through the firewall. He was unclear on how to get it from the trunk to the under seat spot.
    I have found with anything like this a very useful tool is a straightened coathanger - try sticking it thru from where you want it to pop out and then looking for it in the trunk.
    Hope this helps.
    Cheers,
    Andrew
    Nov 2001
    ooo...a coathanger - thats a good idea
    i'll try that tonight
    thanks man!
    -Robert
    Silver 911
    WRX's older brother
