THE BLARG MOD: Intercooler tilt: increases temp drop across the intercooler - Page 9
Page 9 of 9 FirstFirst 123456789
Results 121 to 130 of 130
This is a discussion on THE BLARG MOD: Intercooler tilt: increases temp drop across the intercooler within the Engine Performance forums, part of the Tutorials & DIY category; The amount of air is fixed but the surface area on the IC that the fixed amount of air hits ...
  1. #121
    The amount of air is fixed but the surface area on the IC that the fixed amount of air hits is not.
    I think there were temp measurements provided in one if the threads. I'm impressed with the mod, very high bang:buck.
  3. #122
    Registered User bpeters87's Avatar
    Nov 2011
    Harrisburg, PA
    does anyone know if this can be done on an 11+?
    Bryan | Stink-Eye Mob #265
    07 Impreza Outback Sport, 5spd
    Sad I don't have this anymore:
    2012 WRX Premium, Plasma Blue Pearl hatch, Stage 1+
    check out my build thread
  4. #123
    Registered User blee5192's Avatar
    Aug 2013
    Bay Area
    Hey Blarg,
    Does this mod work for any year wrx? I have a 13' wrx sedan. I was wondering if you have any new pictures or videos of you doing it step by step. Not exactly sure and a little confused. Thank you!
  6. #124
    Blarg had an early car and has not been heard from in years. Have a look under there and see what you've got.
  7. #125
    Jun 2013
    Auckland, New Zealand.
    I've been reading this and it looks like it might be worth a go. So far I've made the spacers. I used some aluminium honeycomb, 2 pieces bonded together to about 3/4" thick.
    I thought the honeycomb would be good because it is lightweight, strong and shouldn't have much heat transfer through it, as it's mostly air.
    I'm waiting for the adhesive to fully cure, then I'll drill the holes and fit. Just in time for the NZ summer. :-)
  8. #126
    Jun 2013
    All done.
    Finished making the spacers:
    Before install:
    After install:
    Fitted spacers:
ID:	124946Click image for larger version.
    Couldn't get a decent shot of before and after through the scoop. The spacer are about 20mm (3/4"). I filled the exposed core on the sides with some Devcon aluminium epoxy just to tidy them up a bit.
  9. #127
    Nice job!
  10. #128
    Oct 2005
    Everywhere: SC
    I did this mod on my 2005 FXT, all the tilt does is make more surface contact with air flowing through TMIC
  11. #129
    Registered User Ampliified's Avatar
    May 2012
    Warren Twp, NJ
    I already have a hard time putting my TMIC back on correctly with the stupid TB hose I'm a little scared to do this mod.
    2012 DGM WRX - Stage Two 93 - Stink Eye Mob #908
    The Epic Life of Emily the WRX
  12. #130
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Ampliified View Post
    This is intended for the earlier generation GD WRXs.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
