I think it might be possible to get a better angle on the tilt using a 45 degree coupler for the outlet (which would have to be cut to fit), and a 90 degree elbow (which would also have to be cut to fit, and a helix IC adaptor, which has a cast aluminum y-piece, and a 90 degree hose to connect to the turbo. Unfortunately, since my efforts are currently focused on finishing my water sprayer, and paying for a laptop I just had to buy because the dog knocked my old one off the table, that experiment will have to wait a bit. I think it would be cool to stand up the IC at a 45 degree angle on top of the motor, which would give you the low lag of a TMIC and the efficiency of a FMIC, and a huge scoop like a supercharger (if you like that sort of thing), but it will have to wait.
Like I said, this was the $3 version that anyone can do. The extreme version will be far more complicated, expensive, and the appearance may not be to everyone's liking, but I do have a person who is willing to make me a custom hood...but I'd still have to buy another hood, and the piping for the mod...I'm probably looking at about $1200 for the experiment. Of course if I can make something like that happen, I'd see if enough people were interested to make a few kits and sell them (I even have access to a person in China that can organize manufacturing some parts for me, but I'd probably have to order a minimum of 500 units or so.
Like I said, its a cool idea, but I'm not sure if people will like it, or how well it will work, or if it will work well enough to be worth the money it would cost to do.
When I DO get around to trying this mod, I'll probably be doing it with a larger aftermarket TMIC, like that cheap eBay one. It requires some work to make it fit anyway, so why not see if I can make it fit at 45 degrees?
LinkBack URL
About LinkBacks
I realy think that will impruve cooling in slower driving situations.
'09 STi stage 1, hope this one will be good too...
But now I have my set up working good enough to feed ambient air into engine 95+% of the time. On a 70 MPH cruse it actualy gets 24C air into engine on a 25C day. Here's my version of how I impruved the IC efficiency, It's not good looking may even be a little ghetto but it WORKS and when hood is closed it gets by and nobody actualy sneeres at it, I hope.
I guess that's what I get for buying a cheap hood. I don't think I'll buy another CF or fiberglass hood. A CF panel might be ok, but its just not as stiff as the OEM metal hood, and at high speeds it flexes (the scoop actually bounces up and down...it sucks) I miss my stock hood.
